--- In bc2000@yahoogroups.com, "dsimag" <dsimag@...> wrote:
> I simply cannot make BCR2000 to work on new 64-bit Windows 7. Here are the facts:
> - Win7 64bit, with all latest updates installed
> - BCR2000 with Behringer's 64-bit driver 1.0.10
> - MIDIOX 7.0.0.365
> - BC Manager - latest release
> I cannot get either BC Manager nor MIDIOX to detect BCR. In Windows device manager everything seems to be OK - it says "device is working properly". MIDIOX reports external error, and BC Manager reports that it cannot detect any units.
Hard to say, in particular since I myself don't have a 64-bit machine yet (let alone Win7 64-bit + Behringer's 64-bit driver).
However, since neither BC Manager nor MIDI-OX can access your BCR, my best guess is that the USB controller on your BCR is defective. In particular the "external error" message seems to indicate this.
But it might also be a setup problem concerning the 64-bit USB driver.
Just to exclude some of the more innocent setup problems:
In BC Manager, do you see the Behringer I/O devices listed under (from the main window:) Options -> MIDI devices -> Input and Output?
The Behringer I/O devices should have checkmarks there.
In the FAQ section of BC Manager manual, take a look at p. 81, question 3, and the question on pp. 84-85, in particular the paragraph about trying a standard MIDI connection.
If BC Manager CAN access your BCR via a standard MIDI connection, the hypothesis that the BCR's USB controller is defective becomes more likely.
Hope this helps,
Mark.
