Roland JX-10 and BCR2000?
2011-05-11 by thermos1979
Hi Folks.  I've got a JX-10 with the Colin Fraser rom in it.  The other 2 roms are 1.9.  Will these older roms inhibit sysex in any way?
And what magic trick am I missing to get learn mode to work between the jx 10 and the BCR20000?  I can get it to learn/see key presses on the JX as well as the c2 slider, but not any of the parameters with the alpha wheel.  Am I missing something?
Re: Roland JX-10 and BCR2000?
2011-05-11 by sghookings@tiscali.co.uk
Could be wrong, but I wonder if your wheel only transmits internally?
Have you tried seeing what MIDI-OX sees when you toggle the wheel?
If it see something, and the learn doesnt, that would be a bit odd.
But of course if MIDI-OX sees nothing, this could be showing the wheel doesnt transmit.
I have a Miniak, and the data dial doesnt transmit jack externally.
Here the trick is to assign the current dial to a Knob X, Y, or Z.
Then midiox DOES see the midi when these dials are moved.
Maybe your synth is same? If not, apologies for the theory.
regards
Steve H
2011-05-11 by baumont987
Withe the Colin Fraser update, the JX does not send Sysex, but does only receive them.
The easiest way to control the JX-10 with the BCF is to use the GB-800 software, it's a PG-800 emulator that can handle automation:
http://greg.baumont.free.fr/?page_id=158&lang=en ;
--- In bc2000@yahoogroups.com, "thermos1979" >
Thanks folks!  I was thinking this, but wasn't sure.  I'm on a mac, and have tried desperately to get that software to work through wine, etc but no avail.  What a headache!
If someone wanted to post a JX-10 template, that would be amazing.
--- In bc2000@yahoogroups.com, "baumont987" <geebeex@...> wrote:
> Hi,
> receive them.
> <http://greg.baumont.free.fr/?page_id=158&lang=en>
Re: [bc2000] Re: Roland JX-10 and BCR2000?
2011-05-11 by James Reeno
Just use the BCR...it works like a charm.
REENO
Funky music For The New Millenium
WWW.SPAZZOID.COM
(Where music still Matters)
On ITunes:
http://itunes.apple.com/us/album/the-real-electrofunk/id354096689
http://itunes.apple.com/us/album/close-encounters-808-kind/id302452252
http://itunes.apple.com/us/album/360-degrees/id312541576
http://itunes.apple.com/us/album/the-acid-jazz-project-vol/id349442979
CD Releases:
WWW.CDBABY.COM/CD/GANGWAYINVASION
WWW.CDBABY.COM/REENO1
WWW.CDBABY.COM/REENO2
WWW.CDBABY.COM/REENO3
WWW.CDBABY.COM/MANOREZAMUSIC
WWW.CDBABY.COM/DRSEXX
Vinyl Releases:
http://www.spazzoid.com/html/RELEASE%202008%20VINYL%20Summer.html
http://www.spazzoid.com/html/RELEASE%202003%20SMD.html
http://www.spazzoid.com/html/RELEASE%202005%20I%20Luv%20it.html
To: bc2000@yahoogroups.com
Sent: Wed, May 11, 2011 6:13:28 PM
Subject: [bc2000] Re: Roland JX-10 and BCR2000?
What a headache!
> Hi,
> receive them.
> http://greg.baumont.free.fr/?page_id=158〈=en
Care to elaborate?  I can't get it to work like a charm.  Do you mean it works in learn mode, or?
> REENO
> WWW.SPAZZOID.COM
> On ITunes:
> CD Releases:
> Vinyl Releases:
> From: thermos1979 <natewood@...>
> What a headache!
> --- In bc2000@yahoogroups.com, "baumont987" <geebeex@> wrote:
> > Hi,
> > receive them.
