Is anyone here running Cakewalk Sonar?
2013-05-01 by Ron Anderson
We're running a beta test program for a new multi-unit bcr2000 plugin for Sonar and need a few good men / women.
betatesting
at
mtmsoftworks
dot
kom
Thanks!
Re: Is anyone here running Cakewalk Sonar?
2013-05-01 by Dylan Endall
not running sonar but do use it every so often. What also needs to be done is a multi bcf for presonus studio one 2. Keeps getting stuck. seems automation takes over and wont respond and occurs only randomly.
Thanks
and thank you to all of you who are working on this for the rest of us dumb as****
Cheers
RE: [bc2000] Re: Is anyone here running Cakewalk Sonar?
2013-05-01 by John Rose
I am currently running X1 and X2 so I will have a look to see if I can help
as I currently have 2 x BCF and a BCR but only have 1 BCF connected in X2 at
the moment
Many thanks
John Rose
(www.astrodevelopments.com)
From: bc2000@yahoogroups.com [mailto:bc2000@yahoogroups.com] On Behalf Of
Dylan Endall
Sent: 01 May 2013 18:07
To: bc2000@yahoogroups.com
Subject: [bc2000] Re: Is anyone here running Cakewalk Sonar?
Thanks
as****
Cheers
Re: [bc2000] Re: Is anyone here running Cakewalk Sonar?
2013-05-02 by Dylan Endall
Well I've gotten two bcf's to work in presonus sx2 although it took a lot of plugging and unplugging and rerouting.  It finally worked when I activated under mackie mode with an extender as midi out/in = bcf 1 for the first bcf. Then midi out/in 2 (under the guise of a mackie extender) under the second bcf as 'usb audio hardware 2' and NOT bcf 2- hope you can follow that, sorry if its confusing.  I can get the 16 channels to work but sometimes during a session it freezes the faders and seems to put them into a write/touch automation mode w2here they slide back to wherever they are in the mix.  Its as if the bcf is saying: "the volume is fine dude leave it alone!" JK
sometimes its an hour before this starts happening and sometimes five minutes and sometimes immediately.
I'm looking to hook up a third bcf and a frontier designs alphatrack (hoing they play well together then solder them with the other two bcfs so it makes one 24 channel transport having daw.  Might even pick up a jl cooper to use the jog wheel.
Let me know how you progress.
Thanks
Dylan
Sent: Wednesday, May 1, 2013 3:19 PM
Subject: RE: [bc2000] Re: Is anyone here running Cakewalk Sonar?
I am currently running X1 and X2 so I will have a look to see if I can help as I currently have 2 x BCF and a BCR but only have 1 BCF connected in X2 at the moment
Many thanks
John Rose
From:bc2000@yahoogroups.com [mailto:bc2000@yahoogroups.com] On Behalf Of Dylan Endall
Thanks
Cheers
