BCR2000 and Wholehog 2 lighting console
2013-05-25 by greg_zeubest
Hi, :)
I'm trying to use a bcr to control a wholehog2 console. I used the "learn" function, and it seems ok for the buttons, but I can't use it for faders.
I can make a fader work, but they are all working together, as there's a missing parameter : velocity.
For this console, we can set faders only to one global note, CC will change the value of the fader, and velocity will choose a specific fader.
I've been searching on the net, but bcedit.jar doesn't seem to handle velocity, and perhaps BC manager can do it, but i don't know how, and I haven't found in the manual.
I Wonder if it's possible to modify a text version of the sysex to add it ?
$encoder 33
.easypar CC 1 64 0 127 absolute
.showvalue on
.mode 1dot
So, can you please help ?
Thank you.
Re: BCR2000 and Wholehog 2 lighting console
2013-05-26 by Royce
Hi
I'm a bit lost on the messages you want to send.
Do you need to select the fader with a Note on message with the velocity being the fader number then send a CC64 message on channel 1?
Fader 3 set to 100
$90 xx 3       ;xx is the global note number
$B0 64 100
Assuming this is correct, to send multiple messages like this you should use something like the following...
encoder 33 is for fader 1 ie velocity =1(?) or should it be 0
global note = 60
 $encoder 33
 .showvalue on
 .mode 1dot
 .minmax 0 127
 .resolution 96 96 96 96
 .tx $90 60 01
 .tx $B0 64 val
You can use my editor in the files section or Mark's editor from his web site to convert this text file (we use the *.bc2 file extension) to sysex and send it to the BC.
All the best
Royce
--- In bc2000@yahoogroups.com, "greg_zeubest" <greg_zeubest@...> wrote:
> Hi, :)
> $encoder 33
> .showvalue on
> .mode 1dot
> Thank you.
2013-05-26 by greg_zeubest
Thank you very much for your help.
Tks to you, I'v understood how to add this velocity parameter. It's not working, but I think there's parameters I don't have for this console... the correct velocity reference to all faders is unknown... even in the manual.
So, i'll continue to search for it.
Tks again.
G.
--- In bc2000@yahoogroups.com, "Royce" <rpcfender@...> wrote:
> Hi
> Fader 3 set to 100
> $B0 64 100
> global note = 60
>  $encoder 33
>  .showvalue on
>  .mode 1dot
>  .minmax 0 127
>  .tx $90 60 01
>  .tx $B0 64 val
> All the best
> Royce
> --- In bc2000@yahoogroups.com, "greg_zeubest" <greg_zeubest@> wrote:
> > Hi, :)
> > $encoder 33
> > .showvalue on
> > .mode 1dot
> > Thank you.
2013-05-26 by sghookings@...
http://forums.highend.com/archive/index.php/t-4600.html
and
MitchOctober 30th, 2007, 03:56 PM
The midi implementation for the Wholehog2 was primarily designed for slaving
two consoles together rather than controlling the system with an outboard
midi controller, though for simple button pushes it is quite adequate. It
is a little more complex for fader events though.
For these the console sends a "fader_val" message (controller) to describe
what value from 0-255 the fader should have and then a "fader" message
(note) to describe which fader that value should be assigned to. It does
this for every increment of the fader.
The best way to see this is to connect two consoles together, enable "midi
in" on one and "notes out" on the other. Then enable the "event monitor" on
the first console so you can see the actual messages (though I appreciate
that not everyone has two consoles!).
If I were to move fader 1 up from 0 to 7 I would see the following messages:
B04000 (Fader value 1)
900A00 (Fader 1)
B04001 (Fader value 2)
900A00 (Fader 1)
B04001 (Fader value 3)
900A00 (Fader 1)
B04002 (Fader value 4)
900A00 (Fader 1)
B04002 (Fader value 5)
900A00 (Fader 1)
B04003 (Fader value 6)
900A00 (Fader 1)
B04003 (Fader value 7)
900A00 (Fader 1)
As you can see the Hog 2 outputs the same message for pairs of values so 255
actually corresponds to a fader_val controller message of 127.
Or to put it another way the fader_val controller message of B04000 is sent
for both 0 and 1 and B04001 is sent for both 2 and 3.
BUT even this info looks suspect?
There doesnt seem to be any state change and yet apparently one is controlling different fades.
Try to monitor the output via MIDI OX and see if you can emulate what it does?
> Tks again.
> G.
> --- In bc2000@...m, "Royce" <rpcfender@> wrote:
> > Hi
> > Fader 3 set to 100
> > $B0 64 100
> > global note = 60
> >  $encoder 33
> >  .showvalue on
> >  .mode 1dot
> >  .minmax 0 127
> >  .tx $90 60 01
> >  .tx $B0 64 val
> > All the best
> > Royce
> > > Hi, :)
> > > $encoder 33
> > > .showvalue on
> > > .mode 1dot
> > > Thank you.
This console, for midi remote, needs to be prepared via a file called MIDIMAP.TXT . In this file , most midi parameters ( notes & controllers) are defined by strings like:
fader_val = controller:65
go:9 = note:28
...etc...
in format: <operation type>:<index> = <message type>:<value>
The problem is that the <index>, for the faders, isn't always known
"Dmx faders uses fader:33  to fader:56 , for expansion wing, fader:57 to fader:90".
A bit complicated for me :-)
G.
> and
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> 900A00 (Fader 1)
> > Tks again.
> > G.
> > --- In bc2000@yahoogroups.com, "Royce" <rpcfender@> wrote:
> > > Hi
> > > Fader 3 set to 100
> > > $B0 64 100
> > > global note = 60
> > >  $encoder 33
> > >  .showvalue on
> > >  .mode 1dot
> > >  .minmax 0 127
> > >  .tx $90 60 01
> > >  .tx $B0 64 val
> > > All the best
> > > Royce
> > > > Hi, :)
> > > > $encoder 33
> > > > .showvalue on
> > > > .mode 1dot
> > > > Thank you.
