Controlling the Marion Prosynth
2014-03-26 by <mfaitkenjr@...>
Joined the group because I've been searching hi and low for a midi controller that can fully control the Marion Prosynth. I have a Roland PCR30 that is able to send NRPN messages to it and works fine for changing positive parameter values. The problem is, there's no way to change value ranges -99 to 99, for example with HRO1 Frequency. Is the BCR2000 able to control the full range from negative to positive. I would even be happy using 2 knobs, one for negative, one for positive. Is it possible? I would buy a BCR2000 if this was possible. Thanks for the groups time. -Frank
Re: Controlling the Marion Prosynth
2014-03-26 by <rpcfender@...>
Although I feel confident that it can, before I say a definite 'yes' you need to show what you mean by -99.
Most data in Midi is only 7bits (0 to 127)
Computers use the hi bit to show it is negative
here I am subtracting 1 from each number and $xx is a hexadecimal number
2 $02
1 $01
0 $00
-1 $FF
-2 $FE
It's a bit confusing with just 8 bit numbers. It might make more sense with an extra byte that is not used
2 $01 02
1 $01 01
0 $01 00
-1 $00 FF
-2 $00 FE
Now Midi can't use all 8 bits for data so usually they split the 8 bits up into 2 bytes
2 $00 02
1 $00 01
0 $00 00
-1 $01 7F
-2 $01 7E
But it could be split in half into 4 bit nibbles in each of the two bytes
2 $00 02
1 $00 01
0 $00 00
-1 $0F 0F
-2 $0F 0E
Unfortunately there are other ways dreamed up by synth makers and who knows what Tom Oberhiem was thinking
I found some stuff here
http://feldkir.ch/marionsystems.htm
but no details on the NRPN in the manual.
Normally for NRPN with a high range of values they are usually handled with (Most significant byte = MSB)
CC99 MSB_NRPN
CC98 LSB_NRPN
CC06 MSB_Value
CC38 LSB_Value
Let me know what the format is and I can tell you if I think the BC2k can do it.
All the best
Royce
Hi, Thanks for replying. Using Roland's PCR editor v1, I enter an NRPN message using the "free message" field and enter values in the fields min: 0 and max: 99 for "DT". The hex number for HRO1 Frequency is 0C and the parameter value range is -99 to 99. With the NRPN message below, I can adjust the value of HRO1 Frequency from 0 to 99. I can't figure out how to assign control values below 0 as the min field in the editor doesn't go below 0.
B0 63 0C B0 62 00 B0 06 00 B0 26 DT
I'm also trying to use sysex but am stumped. This is the Format for an ASM or Prosynth:
F0 system exlusive status 00 Marion Systems manufacturer id... 00 ... 59 ... 01 MSR-2 product id, use 7F as ALL IDs identified
01 MSR-2 ASM product member,use 7F as ALL IDs identifier dd ASM device id, use 7F as ALL IDs identifier pp ASM message type, 4 =Request Data, 3 =Set Data tt ASM data type, 0=global,1=preset,2=layer,3= tuning table,4=patch map,5=velocity curve,6=patch name,7=parameter mm ASM data 14-bit number msb ll ASM data 14-bit number lsb ... data, one 14-bit value per byte F7 End of system exclusive message
This is the format for parameter value data:
F0 00 00 59 01 01 dd 03 07 pm pl vm vl ...F7
Thanks for your help. I'm still learning sysex. Also, it doesn't help that the synth crashes when sending a sysex message (probably cause I'm doing something wrong). - Frank
2014-03-27 by <rpcfender@...>
So from that site
http://feldkir.ch/MSR-2%20SYSEX.txt
ASM System Exclusive Specification
    00  ...
    59  ...
    01  MSR-2 product id, use 7F as ALL IDs identifier
    01  MSR-2 ASM product member, use 7F as ALL IDs identifier
    pp  ASM message type, 4 = Request Data, 3 = Set Data
    tt  ASM data type, 0 = global, 1 = preset, 2 = layer, 3 = tuning table,
                       4 = patch map, 5 = velocity curve, 6 = patch name,
                       7 = parameter
So I guess, to adjust a parameter you use
F0 00 00 59 7F 7F 7F 03 07 MSB_Param LSB_Param MSB_Value LSB_Value F7
Assuming the data is sent the same as the MSR-2
"14 bit signed numbers are used to transmit data values. These are transmitted by sending the most significant 7 bits first and the least significant 7 bits last. Bit 14 represents the sign bit. "
my guess is ....
99 = $00 63
98 = $00 62
2 = $00 02
1 = $00 01
00 = $00 00
-1 = $7F 7F
-2 = $7F 7E
-98 = $7F 1E
-99 = $7F 1D
These are not continuous values as 0 won't wrap around to $7F 7F
To get the BC to handle negative numbers in a continuous way it needs to use an extra bit (ie in this case 15bits)
99 = $01 00 63
98 = $01 00 62
2 = $01 00 02
1 = $01 00 01
00 = $00 00 00
-1 = $00 7F 7F
-2 = $00 7F 7E
-98 = $00 7F 1E
-99 = $00 7F 1D
With a minimum of $00 7F 1D and a max of $01 00 63
and ignore the first byte when you output the message (val 7.13 and val0.6 are the BC commands for the data)
It can't do this as it can only handle 14bits.
If only the 14th bit was not used for negative there is a way to fudge the negative number.
This is the same problem as I have for Emu Morpheus and I have never been able to create a solution.
Try using MidiOx and building a sysex parameter message to make sure that your synth does function that way.
All the best
Royce
Re: [bc2000] Re: Controlling the Marion Prosynth
2014-03-27 by F Aitken
Thanks for the info.  It will take me a little time to absorb. Thank you for your time on the matter.  Just curious, I stumbled upon this doing a search and interested me as I'd like to use NRPN messages since the Prosynth is known to be buggy with respect to parameter changes using sysex.  Is this possible?  See below:
"Hi All
So I found I can get -ve values into Miniak via a bcr but not quite as I
 would like it. I wonder ... can the "push encoder", or indeed one of
the buttons be programmed to take a NRPN value and add a large offset to
 it (click adds on 16184 say?). Here's why I want this:
1] if I extended my code to take two hex values, then suddenly the NRPN stuff becomes clearer
I was passing say 0x241 as a NRPN value from midi-ox.
Of course the C# correctly interprets this as 0x2 x 0x100 + 0x41.
But Midi-ox is infact display 7bit values
IE this should be 0x2 x 0x80 + 0x41 !!
2] Therefore I put midi-ox on the output and could see I _can_ get -ve NRPNs on BCR2000
Set low to be 0, high to be 16384 for NRPN 0xc say (OSC1 waveshape)
Then, 0 -> 100 gives waveshape 0, 100.
Then a massive gap ...
Then from 16284->16384 the -ve values appear :-).
If we could ask the nice people at Berhinger to give a new s14 (for signed 14 bit) that would solve this issue completely.
Then we set the min to be 0x7f1c which is -100 in 7 bit hex (or more simply -100 as a decimal!)"
-Frank
On Thursday, March 27, 2014 1:26 AM, "rpcfender@..." <rpcfender@...> wrote:
So from that site
ASM System Exclusive Specification F0  system exlusive status 00  Marion Systems manufacturer id... 00  ... 59  ... 01  MSR-2 product id, use 7F as ALL IDs identifier 01  MSR-2 ASM product member, use 7F as ALL IDs identifier dd  ASM device id, use 7F as ALL IDs identifier pp  ASM message type, 4 = Request Data, 3 = Set Data tt  ASM data type, 0 = global, 1 = preset, 2 = layer, 3 = tuning table,  4 = patch map, 5 = velocity curve, 6 = patch name,  7 = parameter mm  ASM data 14-bit number msb ll  ASM data 14-bit number lsb ... data, one 14-bit value per byte F7  End of system exclusive message So I guess, to adjust a parameter you use
my guess is ....
99 = $00 63
98 = $00 62
2  = $00 02
1  = $00 01
00 = $00 00
-1 = $7F 7F
-2 = $7F 7E
-98 = $7F 1E
-99 = $7F 1D
99 = $01 00 63
98 = $01 00 62
2  = $01 00 02
1  = $01 00 01
00 = $00 00 00
-1 = $00 7F 7F
-2 = $00 7F 7E
-98 = $00 7F 1E
-99 = $00 7F 1D
All the best
Royce
2014-03-27 by <mfaitkenjr@...>
Hi Royce, Thanks for the detailed info. It will take me a little time to absorb. Thanks for your time on the matter. -Frank
Just curious, I stumble upon this doing a search as I'm interested in using NRPN instead, since the Prosynth is known to be buggy with respect to parameters being changed using sysex . Could this work? See below:
"Hi All
So I found I can get -ve values into Miniak via a bcr but not quite as I would like it. I wonder ... can the "push encoder", or indeed one of the buttons be programmed to take a NRPN value and add a large offset to it (click adds on 16184 say?). Here's why I want this:
Then we set the min to be 0x7f1c which is -100 in 7 bit hex (or more simply -100 as a decimal!)."
2014-03-28 by <rpcfender@...>
The problem is that you can use 14 bits to represent numbers from 0 to 16,383 or -8192 to 8191
Midi doesn't care what you thinking the number means, but being continuous range on steps is the problem
Lets look at the binary numbers as we are talking about bits. 14 bits is 00 0000 0000 0000
This is what you need the BC to do (counting down)
00 0000 0000 0011 = 3
00 0000 0000 0010 = 2
00 0000 0000 0001 = 1
00 0000 0000 0000 = 0
11 1111 1111 1111 = -1 is really taking 1 away from 0 and so we loop back to all '1's
11 1111 1111 1110 = -2 ... continue counting down
11 1111 1111 1101 = -3
This is what it does (counting up)
01 1111 1111 1110 = 8190
01 1111 1111 1111 = 8191
10 0000 0000 0000 = -8192 a big jump right in the middle of the range
10 0000 0000 0001 = -8191 , but only because we think of it as negative number
We fool the BC into being continious by using an extra bit that won't appear in our final outputted value
1 000 0011 = 131 but we think of it as 3
1 000 0010 = 130 but we think of it as 2
1 000 0001 = 129 but we think of it as 1
1 000 0000 = 128 but we think of it as 0
0 111 1111 = 127 but we think of it as -1
0 111 1110 = 126 but we think of it as -2
0 111 1101 = 125 but we think of it as -3
This works for any number as long as you have that extra bit.
Although we are thinking the range is -3 to 3, we make the range of numbers the BC counts from 125 to 131.
Then we ask the BC only to output the lower 7 bits with the command val0.6 - (the value but only use bits 0 to 6 of the 14bit value)
Suddenly we have continuous positive and negative numbers with 0 at the center.
Unfortunately the biggest range the BC can cope with is 14 bits, but we need 15bits to make the 0 appear in the middle of the range.
So wether is it sysex or NRPN the problem remains.
You can, however, either have it jump from 8191 to -8192 in the middle of the range, (but that won't work for -99 to 99 range) or you can use two encoders.
Enc1 range 0 to 99
Enc2 range 16284 to 16383 (-99 to -1) or you reverse it .to go from -1 to -99
Sorry.
Royce
2014-03-28 by F Aitken
Thanks Royce!  It's looking like I may have to buy the BCR2000 soon.  I'm sure there could possibly be other controllers (haven't heard of any others) that can do what you describe (i.e. using 2 knobs, one for the positive, the other for the negative values), but the sheer quantity of knobs on the BCR2000 is very appealing.  From what I've read, it seems like it can control anything.  Thank you for your time.  I've learned alot from you.  Best regards, Frank
Enc1 range 0 to 99
Sorry.
Royce
