CGS 113 Wave Multipliers - BP Caps problem
2013-01-31 by Stephen Richards
Hi Ken
I finally got a hold of the 1uF BP electros for the CGS113 and it turns out the pins are too wide to fit through the PCB !!
I measured the pins width at 0.8mm. I have a 1mm drillbit but am a bit worried about damaging the PCB traces , as i only have a handheld drill ; no drill press.
The other alternative i thought of is to just solder the 1uF BP caps directly to the resistors next to the them (the next thing along on the traces...)
Which would you recommend ?
