Cgs synth
CGS81 as a Stereo Output Mixer questions
2013-12-23 by Stephen Richards
Hi Ken
I have completed the COA panel #4 all except the CGS81 Panel Wiring. All clear sailing with everything working first time ; not calibrated yet.
On the Output Mixer , I have wired only the CCW's (GND Bussed) and CW (Individual Panel Inputs on Each) for the Gain Pots.
My questions are :
Where does the Gain Pot wiper signal go ? Straight to the Pan Pots ?
How do i make a Pan Pot from a Single Gang Pot (...not sure i can from my research.)
Am i right to assume that after the Pan Pots , the signal would go Via the Tip of the AUX Jack to the Tip of the Output Jack ?
Or will i be bussing the Left and Right signals together off the Pan Pots , then to the PCB inputs respectively ; followed by PCB Outs to the Tip of the AUX Jack , then to the Tip of the Output Jack ?
Re: CGS81 as a Stereo Output Mixer questions
2013-12-23 by cg_synth
Look at the schematic. It's practically a wiring diagram.
http://www.cgs.synth.net/modules/cgs81_mixer.html
You will need extra resistors that will be mounted directly between the
pots, at the panel.
Ken
>Hi Ken
>My questions are :
research.)
><head>
><style type="text/css">
>/* start of attachment style */
> .ygrp-photo-title{
> clear: both;
> font-size: smaller;
> height: 15px;
> overflow: hidden;
> text-align: center;
> width: 75px;
> div.ygrp-photo{
> background-position: center;
> background-repeat: no-repeat;
> background-color: white;
> border: 1px solid black;
> height: 62px;
> width: 62px;
> div.photo-title
> a,
> div.photo-title a:active,
> div.photo-title a:hover,
> div.photo-title a:visited {
> text-decoration: none;
> div.attach-table div.attach-row {
> clear: both;
> div.attach-table div.attach-row div {
> float: left;
> /* margin: 2px;*/
> p {
> clear: both;
> padding: 15px 0 3px 0;
> overflow: hidden;
> div.ygrp-file {
> width: 30px;
> valign: middle;
> div.attach-table div.attach-row div div a {
> div.attach-table div.attach-row div div span {
> font-weight: normal;
> div.ygrp-file-title {
> font-weight: bold;
> /* end of attachment style */
> </style>
> </head>
><html><body>
><!-- |**|begin egp html banner|**| -->
><br><br>
><!-- |**|end egp html banner|**| -->
><div style="color:#000; background-color:#fff; font-family:HelveticaNeue,
Helvetica Neue, Helvetica, Arial, Lucida Grande,
sans-serif;font-size:10pt"><div>Hi Ken</div><div><br></div><div
style="color: rgb(0, 0, 0); font-size: 13px; font-family: HelveticaNeue,
'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;
background-color: transparent; font-style: normal; ">I have completed the
everything working first time ; not calibrated yet.</div><div style="color:
rgb(0, 0, 0); font-size: 13px; font-family: HelveticaNeue, 'Helvetica Neue',
Helvetica, Arial, 'Lucida Grande', sans-serif; background-color:
transparent; font-style: normal; "><br></div><div style="color: rgb(0, 0,
transparent; font-style: normal; ">On the Output Mixer , I
Each) for the Gain Pots. </div><div style="color: rgb(0, 0, 0);
font-size: 13px; font-family: HelveticaNeue, 'Helvetica Neue', Helvetica,
Arial, 'Lucida Grande', sans-serif; background-color: transparent;
font-style: normal; "><br></div><div style="color: rgb(0, 0, 0); font-size:
13px; font-family: HelveticaNeue, 'Helvetica Neue', Helvetica, Arial,
'Lucida Grande', sans-serif; background-color: transparent; font-style:
normal; ">My questions are :</div><div style="color: rgb(0, 0, 0);
normal; ">Where does the Gain Pot wiper
> signal go ? Straight to the Pan Pots ?</div><div style="color: rgb(0, 0,
transparent; font-style: normal; ">How do i make a Pan Pot from a Single
Gang Pot (...not sure i can from my research.)</div><div style="color:
transparent; font-style: normal; ">Am i right to assume that
the Tip of the Output Jack ?</div><div style="color: rgb(0, 0, 0);
normal; ">Or will i be bussing the Left and Right signals together off the
?</div></div>
><br>
><br>
><div width="1" style="color: white; clear: both;"/></div>
></body></html>
_______________________________________________________________________
Ken Stone sasami@... otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Hi Ken
I have looked at the Schematic again and what i see it as , is :
Banana > Gain Pot , wired as described in my last email > Wiper of Gain Pot via a 100K Resistor to Wiper of Pan Pot.> Pan Pot CCW to one side of the PCB Input.> Pan Pot CW to other side of the PCB Input ; both with 100K Installed on PCB.> Inverted Outputs of PCB to Left and Right Output Jacks.
Just wanting to figure out if this is right or not.
Thanks again.
pots, at the panel.
Ken
>Hi Ken
>My questions are :
research.)
><head>
> .ygrp-photo-title{
> clear: both;
> font-size: smaller;
> height: 15px;
> overflow: hidden;
> text-align: center;
> width: 75px;
> div.ygrp-photo{
> height: 62px;
> width: 62px;
> div.photo-title
> a,
> clear: both;
> float: left;
> /* margin: 2px;*/
> p {
> clear: both;
> overflow: hidden;
> div.ygrp-file {
> width: 30px;
> valign: middle;
> font-weight: bold;
> </style>
> </head>
><html><body>
><br><br>
?</div></div>
><br>
><br>
></body></html>
Hi Stephen,
not even close, I'm afraid. you are still trying to wire it as a processor.
There are 47k and 150k resistors involved and you didn't even mention them.
Pan pot wiper goes to ground. Follow the actual link I gave you and look at
the diagram on that page.
>Just wanting to figure out if this is right or not.Â
>Thanks again.
Drokk !! Sorry Ken. I did not look at the actual link you gave me , that's much clearer. I'm sure i can sort it from there.
Thanks and Happy Xmas to you and the Ponies.
On Monday, December 23, 2013 10:23 PM, "sasami@..." <sasami@...> wrote:
Hi Stephen,
>Thanks again.
