Pedals not working
Pedals not working
2013-12-24 by James W Kenney
We have a Mark IV which was recently tuned. My son noticed that the pedals are not working. Is there a software switch somewhere?
Jim
Re: [disklavier] Pedals not working
2013-12-24 by Bill Brandom
Jim,
- Power down your Mark IV. (Hold in the oblong ON/OFF button until it starts blinking. When it finishes blinking it is powered down.)
- Unplug your piano from your A/C outlet and let the piano sit for about an hour.
- Plug back in your piano and power up.
- Your pedals should now work.
(If this fixes your piano, then you have experienced a little bug in the Mark IV. It typically happens if you have left your piano on for several weeks. About every 2 weeks I go through the above procedure. Since I have been doing that, I have not experienced a pedal playback problem.)
Merry Disklavier Christmas!
Bill Brandom
Jim
Bill
Your procedure worked! Thank you for my Christmas gift. I have one very happy son.
Jim
To: disklavier <disklavier@yahoogroups.com>
Sent: Tue, Dec 24, 2013 2:49 pm
Subject: Re: [disklavier] Pedals not working
Jim,
Bill Brandom
Jim
Great news!
Merry Christmas!!
Bill
Sent from my iPhone.
On Dec 24, 2013, at 2:05 PM, James W Kenney <jimwkenney@...> wrote:
Bill
Jim
Jim,
Bill Brandom
> On Tue, Dec 24, 2013 at 8:53 AM, James W Kenney <jimwkenney@netscape.net> wrote:
> Jim
2013-12-25 by Adrian Thomas
On the Mark IV, it's also a good idea to go through the pedal calibration when work has been done to it. Click on the little reddish icon at the bottom left of the remote, go to Service Centre and select Pedal Calibration.
Adrian Thomas
On Dec 24 2013, Bill Brandom wrote:
>Great news!
>Merry Christmas!!
>Bill
>On Dec 24, 2013, at 2:05 PM, James W Kenney wrote:
>Bill
>Jim
>-----Original Message-----
>From: Bill Brandom
>To: disklavier
>Jim,
>Bill Brandom
>> Jim
... and a Merry Christmas and and a happy New Year to everyone. I know it's a bit late but it's a busy week.
Adrian Thomas
>Great news!
>Merry Christmas!!
>Bill
>Bill
>Jim
>From: Bill Brandom
>To: disklavier
>Jim,
>Bill Brandom
>> Jim
2013-12-26 by lderosa@...
We are also having troubles with the pedals. I tried the suggested procedure and they are still not working. Do you have any other suggestions?
Linda
> Adrian Thomas
> >Great news!
> >Merry Christmas!!
> >Bill
> >Bill
> >Jim
> >From: Bill Brandom
> >To: disklavier
> >Jim,
> >Bill Brandom
> >> Jim
2013-12-28 by <gward1211@...>
Hi Bill
I also have a Mk IV (C3 DKV). I experience the pedal problem often, 3 times in the space of an hour when playing files on the HDD through DKVBrowser. I can fix it simply by going to standby mode and on again. I rarely have the problem when playing midi files from my laptop using VanBasco's Karaoke Player.
I power down and turn the power off at the wall socket every night.
This seems to be an identifiable and common bug affecting a lot of users - probably every Mk IV user. Do you know why Yamaha doesn't put out a fix for it?
Many thanks for your knowledge, wisdom and help in these pages.
Geoff
Long live Disklavier
2013-12-28 by Bill Brandom
Hi Geoff,
I am sorry to hear about the problems you explained in your email. If your pedals are failing as often as you say, then you have a hardware problem. Having your pedals quit 3 times an hour is NOT the norm with the Disklavier Mark IV and is a problem that needs to be corrected. The problem I described in an earlier post is something that occurs after leaving the Disklavier on for long periods of time (typically longer than 2 weeks.) This problem is corrected by doing a complete power down, disconnecting it from power and letting it "rest" for 30 minutes or more. Through the years of Mark IV production, this problem was pretty much solved, but not totally eliminated. I have found that if I go through this power down procedure about once a week, then I never have a pedal playback problem.
Lets troubleshoot this a little bit. How old is your piano? If you are not sure, give me the serial number of the piano (a seven digit number on the plate or harp) located under the treble end of the music desk. How long has this problem been happening? Have you reported this problem to Yamaha? If so, what was recommended and what was the result? When was the last time you had the piano calibrated? Has your piano been updated to the latest operating system?
If I was there, I would try the following. Normally this is done by a Disklavier technician, but if you are careful, you can do it yourself. Power down the piano again and disconnect it from power. On the back side of the key drive unit under the treble end of the piano, you will find a box that contains the CSP (Central Signal Processor) board. There are a number of RCA connections to this box. Disconnect and re-insert the the two connectors labeled TO I/O BLUE and GREEN. Disconnect and re-insert the connector labeled TO PD. Go to the I/O unit and disconnect and re-insert the BLUE and GREEN connectors located on one end of the I/O Center above the LAN connector.
Plug the piano back into the A/C and power back up. Record a two minute song of playing the damper pedal and shift pedal (right and left pedals), depressing each pedal every two seconds. Then, play this song back 4 or 5 times. If the pedals continue to work, then play your music as you normally do and see if the pedals continue playing or not.
Let me know the results. Hopefully, your pedal issue is solved.
Bill
On Fri, Dec 27, 2013 at 7:27 PM, <gward1211@...> wrote:
Hi Bill
Geoff
Hi Linda,
I am sorry I didn't get back to you sooner. I have just responded to a pedal problem Geoff has described in his post. I recommend you try the same thing.
FROM MY POST TO GEOFF:
Bill
Linda
Adrian Thomas
>Great news!
>Merry Christmas!!
>Bill
>Bill
>Jim
>From: Bill Brandom
>To: disklavier
>Jim,
>Bill Brandom
>>; Jim
2013-12-28 by lderosa@...
Hi Bill, So I just did all this and the left pedal started to work a few times and then stopped. Would there be any point in trying again?
Linda
> On Dec 28, 2013, at 11:02 AM, Bill Brandom <bill.brandom03@...> wrote:
> Hi Linda,
> Bill
>> Thanks,
>> Linda
>> Sent from my iPhone
>>> Adrian Thomas
>>> >Great news!
>>> >Merry Christmas!!
>>> >Bill
>>> >Bill
>>> >Jim
>>> >From: Bill Brandom
>>> >To: disklavier
>>> >Jim,
>>> >Bill Brandom
>>> >> Jim
2013-12-28 by Adrian Thomas
If, after the adjustments I posted earlier, you still have problems, you're likely to have hardware problems. One thing to try is to measure the resistance of the working pedal (there should be a simple, 2-pin connector) and compare it to the resistance on the faulty pedal. The faulty pedal usually has a much lower resistance.
Adrian Thomas
>Thanks,
>Linda
>Sent from my iPhone
>> On Dec 28, 2013, at 11:02 AM, Bill Brandom wrote:
>> Hi Linda,
>> Bill
>>> Thanks,
>>> Linda
>>> Sent from my iPhone
>>>> Adrian Thomas
>>>> >Great news!
>>>> >Merry Christmas!!
>>>> >Bill
>>>> >Bill
>>>> >Jim
>>>> >From: Bill Brandom
>>>> >To: disklavier
>>>> >Jim,
>>>> >Bill Brandom
>>>> >> Jim
Linda,
Probably not. Do you know when you last had the Disklavier system adjusted and calibrated? It sounds like this is probably necessary.
Before you do anything else, try the following:
Tap on the MENU icon at the bottom of the screen on your PRC-100. Then tap on SERVICE CENTER. Then tap on #3 PEDAL CALIBRATION. This will start pedal calibration. It will take about 2 minutes. At the end of the calibration you will hear either a C Major chord (I call the happy chord) or a C Minor chord ( Unhappy chord that indicates there is a problem with the pedals and they probably need adjustment.) C Major chord = C E G. C Minor chord = C Eflat G. Also there will be a display on your screen. Let me know what the last 3 or 4 lines say.
If your piano only requires pedal calibration and you get a C Major chord, then the pedals should now work.
Let me know.
Bill
Linda
Hi Linda,
Bill
Linda
Adrian Thomas
>Great news!
>Merry Christmas!!
>Bill
>Bill
>Jim
>From: Bill Brandom
>To: disklavier
>Jim,
>Bill Brandom
>> Jim
RE: [disklavier] Pedals not working
2013-12-29 by Geoff Ward
Hi Bill
Thanks for your detailed reply.
I have carried out the tasks you set and the pedals worked flawlessly.
The piano in 9 months old - purchased March 2013 from a Yamaha Australia
dealer.  The serial no. is 6338593.  I would be interested to know when it
was manufactured.
The problem only occurred yesterday when I was playing around with
DKVBrowser.  After the comment in these pages "The best software since the
dawn of time", I thought I should check it out some more.  The only files I
played were those demo and sample files which came with the DKV (I retain
all my music files on a laptop which I connect to the DKV wirelessly via
USB).  In doing that the pedals stopped working 3 times.  The first time I
completely powered down and fixed it.  The 2nd and 3rd times, going to
standby was sufficient.
The piano has the latest operating system and was calibrated when new. I
think the pedal problem I experienced yesterday will remain a mystery.
Another question, if I may:  How often should a full keyboard calibration be
done?  I have the full service manual and have previously done a full
calibration myself.
Kind regards
Geoff
  _____
From: disklavier@yahoogroups.com [mailto:disklavier@yahoogroups.com] On
Behalf Of Bill Brandom
Sent: Sunday, 29 December 2013 6:00 AM
To: disklavier@yahoogroups.com
Hi Geoff,
operating system?
connector.
Bill
Hi Bill
for it?
Geoff
2013-12-29 by Bill Brandom
Hello again Geoff,
It sounds like your pedals are now working OK. That is good news!
Your piano is quite new. My serial number list doesn't go high enough to include your piano's serial number. My guess is your piano is 1 - 1.5 years new.
How often to calibrate? This is always an interesting question. According to the Disklavier engineers, they recommend calibrating whenever something has changed with the action or the pedals of the piano. Because a piano is made of wood and felt, things change as humidity changes. I calibrate my piano about every two - three weeks. Why? IF something has changed during the last few weeks, I want my Disklavier system to be best able to play my piano in its current condition.
For most people, however, assuming they are having their piano tuned at least twice a year, they should have their piano calibrated whenever it is tuned.
Bill
On Sat, Dec 28, 2013 at 7:17 PM, Geoff Ward <gward1211@...> wrote:
Hi Bill
The piano in 9 months old – purchased March 2013 from a Yamaha Australia dealer. The serial no. is 6338593. I would be interested to know when it was manufactured.
The problem only occurred yesterday when I was playing around with DKVBrowser. After the comment in these pages “The best software since the dawn of time”, I thought I should check it out some more. The only files I played were those demo and sample files which came with the DKV (I retain all my music files on a laptop which I connect to the DKV wirelessly via USB). In doing that the pedals stopped working 3 times. The first time I completely powered down and fixed it. The 2nd and 3rd times, going to standby was sufficient.
The piano has the latest operating system and was calibrated when new. I think the pedal problem I experienced yesterday will remain a mystery.
Another question, if I may: How often should a full keyboard calibration be done? I have the full service manual and have previously done a full calibration myself.
Kind regards
Geoff
From: disklavier@yahoogroups.com [mailto:disklavier@yahoogroups.com] On Behalf Of Bill Brandom
Hi Geoff,
Bill
Hi Bill
Geoff
2013-12-29 by Kevin Goroway
Hi Geoff,
I don't think DKVBrowser has anything to do with this.  My best guess is that the songs that you are playing when using DKVBrowser are somehow exercising the pedals quite a bit more than the songs that you normally play from your laptop.  If this is a reproducible situation, you might want to try moving some of the songs from your laptop to the piano's "From-To-PC" folder, and then play them from DKVBrowser.  You should experience the same pedal-failure rate as playing from your laptop directly.  (I think the demo songs on the MarkIV are marked as "don't copy", so you probably can't do the reverse.)
You also said that you play your files from your laptop "wirelessly via USB".  I'm confused.  I assume you mean that you are playing MIDI files (using what player?) via USB, but the wireless part has me intrigued.
Anyway, for further conversations on DKVBrowser, I run a yahoo group dedicated to the software over here:
http://groups.yahoo.com/neo/groups/dkvbrowser/info
Enjoy!
-Kevin
Sent: Saturday, December 28, 2013 10:17 PM
Subject: RE: [disklavier] Pedals not working
Hi Bill
Kind regards
Geoff
From:disklavier@yahoogroups.com [mailto: disklavier@yahoogroups.com ] On Behalf Of Bill Brandom
6:00 AM
not working
Hi Geoff,
connector.
Bill
On Fri, Dec 27, 2013 at 7:27 PM, <gward1211@bigpond.com>
wrote:
Hi Bill
I also
I power down
This
it?
Many
Geoff
Long live
2013-12-31 by Geoff Ward
Hi Kevin
I agree that it's not DKVBrowser that causes the problem, but the files
supplied by Yamaha.  I can reproduce the problem just using the PRC 100.
I've worked out the problem and it is reproducible.  In the music files that
came with the DKV, there is a file called "Introduction to the Piano" (intro
piano.pspg) in a  folder called PianoSoft Plus Graphics (Demo).  Towards the
end of this file is a pedal demonstration which plays a segment from Fur
Elise.  If I drag the progress slider in DKVBrowser (or the PRC 100) back a
bit to play the pedal demo again (why would anyone want to do that!) it
often disables the sustain pedal.  The soft pedal continues to function and
going to Standby and back again restores the sustain pedal function.
Another file in the same folder is Fur Elise itself and this also produces
peculiar results.  Each time I play it (including from a power-down and
reboot of the piano and laptop - I also did a reset to factory defaults),
the right hand plays the acoustic piano and the left hand plays the Tone
Generator piano (and no LH key movement).  This is easily fixed by changing
the Piano Part Ch R in Song details in DKVBrowser from ## to 2.  I don't
understand this, as it is the left hand that is not functioning correctly,
not the right hand.  Piano Part CH L was set to 1.  Why also would Yamaha
create files to showcase their pianos which don't play properly?  I have
also found other files where the setting for Piano Part Ch R is ##.  This
leads me to wonder whether there could be something wrong with my setup
which is causing the DKV to not respond correctly?  Any comments on this
would be welcome.
You asked about my wireless setup.  I use vanBasco's Karaoke Player to play
my midi files on the DKV using a Sony Vaio laptop.  I like the very
versatile playlist manager in vanBasco and I have several hundred midi files
with lyrics added by means of the great piece of software - Lyric Adder -
offered by Spencer Chase (http://www.spencerserolls.com).  VanBasco is
perfect for my needs.  My real interest lies in collecting and creating midi
files from player piano rolls.  I also have a QRS keyboard scanner under the
keys of a player piano and can make respectable midi copies of 88 note rolls
from my roll collection.  More than 10,000 midi files from scanned rolls are
available online, including more than 5,000 from Spencer Chase.
I have a NETGEAR wifi extender mounted under the piano and connected to that
is a device from IO Gear (iogear.com) called a wireless 4 port USB sharing
station  (GUWIP204).  This device essentially gives me a wireless USB link
to the USB port of the DKV, using my home wifi network.  The NETGEAR wifi
extender also has the normal Ethernet cable connection to the DKV to give
the DKV a connection with the internet, my iPhone and DKVBrowser.  As a
later improvement, I mounted a separate router under the piano and set this
up to provide an extra, dedicated network comprising the DKV and my laptop
only, with no internet connection.  On Christmas day there were more than 10
devices connected to my home wifi network (kids with iphones and iPads, etc)
and this interfered with the orderly flow of data to the DKV.  Having a
dedicated wifi network for the DKV with no internet also means that bulky
updates from Microsoft and McAfee, etc. don't interrupt the data flow to the
DKV (as sometimes happened in the past).  One downside is that I now have
different networks for DKVBrowser and vanBasco.  I might have to re-think
the use of the second router.
With this arrangement, I can play midi files wirelessly from my laptop on
the DKV from anywhere in the house.  I also use Cakewalk home studio for
recording midi files from the piano, and this also works over the wifi USB
link.
So, installed under my piano at the moment is a network extender, a router,
a wireless USB link and 2 powerboards - one always on and one switched by
the DKV.  There's not much space left.
Kind regards
Geoff
  _____
Behalf Of Kevin Goroway
Sent: Monday, 30 December 2013 12:11 AM
Hi Geoff,
reverse.)
Enjoy!
-Kevin
  _____
Hi Bill
was manufactured.
calibration myself.
Kind regards
Geoff
  _____
From: disklavier@yahoogroups.com [mailto: disklavier@yahoogroups.com ] On
Hi Geoff,
operating system?
connector.
Bill
Hi Bill
for it?
Geoff
2013-12-31 by Kevin Goroway
Thanks for the info!  Now I fully understand.
I must say,. though...I don't think my piano behaves the way yours does when playing Fur Elise from the demo folder.  My pedals certainly don't freeze up when playing that section... Something sounds screwy.
-Kevin
Sent: Monday, December 30, 2013 8:52 PM
Hi Kevin
I agree that it’s not DKVBrowser that causes the
problem, but the files supplied by Yamaha.  I can reproduce the problem just
using the PRC 100.  I’ve worked out the problem and it is
reproducible.  In the music files that came with the DKV, there is a file
called “Introduction to the Piano” (intro piano.pspg) in a
folder called PianoSoft Plus Graphics (Demo).  Towards the end of this
file is a pedal demonstration which plays a segment from Fur Elise.  If I
drag the progress slider in DKVBrowser (or the PRC 100) back a bit to play the
pedal demo again (why would anyone want to do that!) it often disables the
sustain pedal.  The soft pedal continues to function and going to Standby
and this also produces peculiar results.  Each time I play it (including
from a power-down and reboot of the piano and laptop – I also did a reset
to factory defaults), the right hand plays the acoustic piano and the left hand
plays the Tone Generator piano (and no LH key movement).  This is easily
fixed by changing the Piano Part Ch R in Song details in DKVBrowser from ## to
2.  I don’t understand this, as it is the left hand that is not
functioning correctly, not the right hand.  Piano Part CH L was set to
1.  Why also would Yamaha create files to showcase their pianos which
don’t play properly?  I have also found other files where the
setting for Piano Part Ch R is ##.  This leads me to wonder whether there
could be something wrong with my setup which is causing the DKV to not respond
correctly?  Any comments on this would be welcome.
vanBasco’s Karaoke Player to play my midi files on the DKV using a Sony
Vaio laptop.  I like the very versatile playlist manager in vanBasco and I
have several hundred midi files with lyrics added by means of the great piece
of software – Lyric Adder - offered by Spencer Chase (http://www.spencerserolls.com).
VanBasco is perfect for my needs.  My real interest lies in collecting and
creating midi files from player piano rolls.  I also have a QRS keyboard
scanner under the keys of a player piano and can make respectable midi copies
of 88 note rolls from my roll collection.  More than 10,000 midi files
from scanned rolls are available online, including more than 5,000 from Spencer
Chase.
and connected to that is a device from IO Gear (iogear.com) called a wireless 4
port USB sharing station  (GUWIP204).  This device essentially gives me a wireless USB
link to the USB port of the DKV, using my home wifi network.  The NETGEAR
wifi extender also has the normal Ethernet cable connection to the DKV to give
later improvement, I mounted a separate router under the piano and set this up
to provide an extra, dedicated network comprising the DKV and my laptop only,
dedicated wifi network for the DKV with no internet also means that bulky updates
from Microsoft and McAfee, etc. don’t interrupt the data flow to the DKV
files wirelessly from my laptop on the DKV from anywhere in the house.  I
also use Cakewalk home studio for recording midi files from the piano, and this
also works over the wifi USB link.
is a network extender, a router, a wireless USB link and 2 powerboards –
one always on and one switched by the DKV.  There’s not much space
left.
Kind regards
Geoff
From:disklavier@yahoogroups.com [mailto: disklavier@yahoogroups.com ] On Behalf Of Kevin Goroway
12:11 AM
not working
Hi
Geoff,
I don't think
You also said that
Anyway, for further
here:
Enjoy!
-Kevin
10:17 PM
not working
Hi Bill
reply.
Kind regards
Geoff
6:00 AM
not working
Hi Geoff,
I am sorry to
playback problem.
Lets
If I was
Plug the
Let me know
Bill
On Fri, Dec
wrote:
Hi Bill
I also have a
I power down
This seems to
Many thanks
Geoff
Long live
Smart pianosoft
2013-12-31 by Cliff DeGuzman
I just purchased a DGB1KE3C (traded in our Mark II XG) and I am enjoying all the wonderful features. We also subscribed to Disklavier radio and TV.
Now I would like to try out smart pianosoft titles but I am wondering how it works. I see that some titles can be purchased and downloaded. Once I have the file downloaded and copied to the hard drive of the DKC-800 and insert the corresponding audio CD in the CD tray, will the system automatically figure out the file that it should play in sync with the CD? Or do I have to manually select the file?
Any help would be appreciated!
Thanks in advance.
Cliff
2014-01-20 by Geoff Ward
Hello Bill
Having gone into the DMP area from the Service Center Menu of my Mark IV, I
find the following calibration Options:
3. Piano Calibration - Full
   1. Calibrate in series w/ GS check
   2. Calibrate in series w/o GS check
   3. Sensor Calibration w/ GS check
   4. Pedal Calibration
   5. Key Drive Calibration
   6. Pedal HP Adjustment
4. Piano Calibration - Extra
   1. Sensor - Extra
   2. Key Drive - Extra (All Keys)
   3. Key Drive - Extra (One Key)
   4. Key Drive - ppp Adjustment.
Would you be kind enough to suggest which items I should choose to give a
full (thorough) calibration of the DKV.
Kind regards
Geoff
  _____
Sent: Sunday, 29 December 2013 2:38 PM
Hello again Geoff,
new.
tuned.
Bill
Hi Bill
was manufactured.
calibration myself.
Kind regards
Geoff
  _____
Hi Geoff,
operating system?
connector.
Bill
Hi Bill
for it?
Geoff
2014-01-20 by Bill Brandom
Just run 3.1 (Full) CALIBRATE IN SERIES WITH GS check.
Bill
On Jan 19, 2014, at 5:58 PM, "Geoff Ward" <gward1211@...> wrote:
Hello Bill
Having gone into the DMP area from the Service Center Menu of my Mark IV, I find the following calibration Options:
3. Piano Calibration – Full
4. Piano Calibration – Extra
   1. Sensor – Extra
   2. Key Drive – Extra (All Keys)
   3. Key Drive – Extra (One Key)
   4. Key Drive – ppp Adjustment.
Would you be kind enough to suggest which items I should choose to give a full (thorough) calibration of the DKV.
Kind regards
Geoff
Hello again Geoff,
Bill
Hi Bill
Kind regards
Geoff
Hi Geoff,
Bill
Hi Bill
Geoff
Re: [disklavier] Stuck Key
2014-01-20 by Sheldon H. Deluty, M.D.
Good Evening:
I have a Mark II Baby Grand with a DKC850 upgrade
The middle E (just above middle C) key now gets stuck halfway down each time it is "played" by the Disklavier (not when played manually) - I have to bring it up or it stays halfway down
What would be involved in repairing such a problem?
Thank you
Sheldon Deluty
2014-01-20 by Skanter123
From a new DKL owner: why, when and how does one calibrate?
Sam
www.keyboardcollective.com
(212) 684-3304
> On Jan 19, 2014, at 8:58 PM, "Geoff Ward" <gward1211@...> wrote:
> Hello Bill
>    1. Sensor – Extra
> Kind regards
> Geoff
> Hello again Geoff,
> Bill
> Hi Bill
> Kind regards
> Geoff
> Hi Geoff,
> Bill
> On Fri, Dec 27, 2013 at 7:27 PM, <gward1211@bigpond.com> wrote:
> Hi Bill
> Geoff
Hi Sheldon,
The solenoid plunger goes through a tube in the center of the solenoid coil. It sounds like the inside of the tube has distorted out-of-round just a bit. If I am correct on my diagnosis, correcting it is not difficult.
The action has to be pulled from the piano in order to be able to have access to the solenoid plunger that is "sticking." Unless you are comfortable removing the action, you should have a piano technician remove the action from the piano. Then pull the plunger from the solenoid coil.
Remove the rubber cap from the end of the plunger. Take a piece of 400 - 600 grit sandpaper and roll it into a tube, with the abrasive on the inside. The plunger is coated will a molybdenum dry lubricant, which is very sandable. Holding the plunger at the rod end (where the cap was) spin it inside the sandpaper tube. Pull it out and test it. (We use the sandpaper tube to make sure we keep the plunger round.) Wipe off the plunger. The plunger should fall free into the coil. If not, spin it again in the sandpaper tube and check. Continue as necessary.
While you are at it, check your other plungers by simply lifting them up and letting them fall back into their coils. If any are slow, sand them.
Bill
On Sun, Jan 19, 2014 at 7:07 PM, Sheldon H. Deluty, M.D. <mdshd@...> wrote:
Good Evening:
Thank you
Sheldon Deluty
2014-01-20 by Adrian Thomas
If the acoustic side of things is OK (i.e. the doesn't stick when playing normally, there may be a problem with the key solenoid.
Adrian Thomas
On Jan 20 2014, Sheldon H. Deluty, M.D. wrote:
>Good Evening:
>Thank you
>Sheldon Deluty
Smart pianosoft
2016-03-29 by Michael Jurewicz
So I got this message from a customer recently, and I honestly do not have much experience messing around with the smart pianosoft function of the disklavier. Anyone have any ideas?
My first thought was to go and change a setting in the "audio I/O" settings from the setup menu. Otherwise, I'm not too sure. ...
After we did the calibration using the DKC-55 box we have been testing the
Smart Pianosoft disk performance with the piano playing its accompanying
audio cd.  It seems that the piano is slightly ahead of the audio CD after
the calibration.  Could this have something to do with us not being able to
calibrate it with the DKC-850 box and having to use the old box?
Thanks!
Michael
Re: [disklavier] Smart pianosoft
2016-03-29 by George Frederick Litterst
Good afternoon, everyone.
Michael, am I correct in assuming that you have connected the DKC-850 to the DKC-55 using MIDI cables? If so, is the MIDI In Delay on the DKC-55 set On or Off? I suspect that it is On when it should be Off.
PianoBench
> On Mar 29, 2016, at 12:42 PM, Michael Jurewicz michaelf.jur@... [disklavier] <disklavier@yahoogroups.com> wrote:
> Thanks!
> Michael
I'm not sure about that one as the customer himself both installed and calibrated the dkc850 himself. I can only ask him through email but I will find out. Isn't his unit a replacement though? Should the dkc-55 setting not matter ?
> On Mar 29, 2016, at 1:13 PM, George Frederick Litterst PianoBench@... [disklavier] <disklavier@yahoogroups.com> wrote:
> Regards,
> PianoBench
>> Thanks!
>> Michael
2016-03-30 by George F. Litterst
Good evening, everyone.
Michael, according to the DKC-850 documentation, the DKC-850 can be installed as a complete replacement for the DKC-55. I was presuming  from your email that the DKC-55 was still connected to the piano—which would mean that the DKC-850 is connected by MIDI cables.
PianoBench
> On Mar 29, 2016, at 2:51 PM, Michael Jurewicz michaelf.jur@... [disklavier] <disklavier@yahoogroups.com> wrote:
> Sent from my iPhone
> On Mar 29, 2016, at 1:13 PM, George Frederick Litterst PianoBench@... <mailto:PianoBench@...> [disklavier] <disklavier@yahoogroups.com <mailto:disklavier@yahoogroups.com>> wrote:
>> Regards,
>> PianoBench
>>> On Mar 29, 2016, at 12:42 PM, Michael Jurewicz michaelf.jur@... <mailto:michaelf.jur@...> [disklavier] <disklavier@yahoogroups.com <mailto:disklavier@yahoogroups.com>> wrote:
>>> Thanks!
>>> Michael
