> On Oct 11, 2015, at 1:38 AM, rightnightboy@... [disklavier] <disklavier@yahoogroups.com> wrote:
> Thanks Iheitzeb1, I guess the wireless connection must be the answer since I get nothing anything under "network" and any attempt to use the "go to folder" with the prompt "smb://dkv <smb://dkv>..." brings nothing. Samething with the "connect to server" : nothing works ( I tried with different syntaxes etc. So probably through wifi the Mac connects with the bridge which in its turns connect to the DKC...
> I found the post where Georges Frederick Litterst says that the Mac finder from 10.7 cannot see the dkc and its suggestion to use mucommander:
> "George Frederick Litterst
> Aug 22, 2013
> Good morning, everyone.
> I have learned officially that the E3/DKC-850 cannot be accessed by the Mac Finder in OS X 10.7 and OS X 10.8. However, there is a free program called muCommander (http://www.mucommander.com <http://www.mucommander.com/>) that will provide access to the From/To PC folder.
> The program presents a window with a split screen. On one side, you access the directory of your Mac. On the other side, you access the E3/DKC-850. To access the E3/DKC-850, you must specify SMB as the protocol and put in an address s imilar to this:
> <>smb://dkv4d073d <smb://dkv4d073d>
> To find the "dkv" number for your Disklavier, you can do either of two things:
> (1) Note what dkv number shows up in the sidebar of a Finder window in the "SHARED" section.
> or
> (2) On your Disklavier, go to Setup : Network : Information : Name
> When you use muCommander to log into your Disklavier, a window will pop up asking for a username and password. You can log in as a guest wit hout a username and password.
> NOTE: muCommander will only give you access to the From/To PC folder. If you want more functionality than that, you should get DKVBrowser (http://dkvbrowser.sourceforge.net <http://dkvbrowser.sourceforge.net/>). To use DKVBrowser, you'll need to identify the current IP address for your E3/DKC-850. To do so, go to Setup : Network : Information : IPAddr.
> Regards,
> PianoBench"
> Now there maybe other workaround... I will eventually try to find a wifi bridge to test the wireless connection.
