not sure who is asking about the MIDI file editing so here is a general reply. first, as far as i know, there are sequencers (or editors) for the Mac for MIDI that are probably excellent since a lot of music professionals use Mac exclusively.
my experience is with PCs. there are several programs for PCs but most are less than wonderful for MIDI as most are geared toward audio these dys not MIDI. so, my favorites are the older Cakewalk programs before it devolved into Sonar. these would be Cakewalk pro audio 9 and Cakewalk Home studio 2002. unfortunately there may be some issues with modern computers running these versions but the problems are possible to work around. i have both programs running on win 10 and have no problems at all after fixing a few odd things to be compatible. there is also the possibility of running any of these old programs in a virtual XP environment. i do not need to do this with Cakewalk because it works fine on my computer (in fact on large 4K display it is very nice to use) but i do run other program using VirtualBox which is a free virtualization system.
editing pedal data is not going to be easy with a sequencer especially if there is proportional pedal. there will be literally thousands of events (yes they are controller events) and if you have many files with problems there will be millions of them.
i have written many (hundreds actually) of utilities for manipulating MIDI files over the last 20 or so years. i use these mainly for my own needs but share them freely with others. i have a few programs that deal with pedal events and people have reported success fixing things like klunking pedals in files from the internet.
of course the first thing to do is to make sure your piano is properly regulated and has no worn or broken parts in the pedal mechanisms. although you might be able to modify the pedal events to compensate for other problems, this is not the best approach.
there are a few utilities on my download page that deal with pedal issues. they all work in batch mode so you do not need to open individual midi files. i believe that the pedal utilities on the site are up to date but anyone who finds the programs useful and is going to use them much is encouraged to contact me to be sure they have the latest greatest version.
Best regards, Spencer Chase
67550-Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
21220 92nd Place W., Edmonds, WA 98020
Spencer@...
Spencer@poodlex.com
Spencer@...
http://www.spencerserolls.com
http://www.poodlex.com
(425) 791-0309
(707) 223-8212
------ Original Message ------
Sent: 5/13/2017 9:35:19 AM
Subject: [disklavier] pedal noise question
Greetings! Now that you helped me control by Disklavier Mark IIXG remotely from the computer in the next room via Bluetooth wireless, I have discovered another problem. For years I auditioned my MIDI files using the computer synthesizer. Now I can listen to them actually playing the piano! To my surprise, many files are corrupted and won’t play from my computer, but I can redo those and test them in real time.
However, yesterday, on many files, I could hear the pedal noise (loud clunk) all the way into the next room! So far today, I have not had that problem, but I think it is the data on some files, so it depends upon what files you are playing.
Am I correct in assuming this is a controller message that operates the pedal? I assume the value is between 0 and 128? Where to I find the controller message in editing software? To be specific, since I am operating on an iMac running Sierra, I will be using Logic Pro 9 to edit MIDI files providing I figure out how to even load a MIDI file and find the controller.
I also own a Windows 7 laptop where I converted (backed up) the ESEQ files to MIDI files. I realize that a lot of Disklavier utility software only works on Windows, so let me know if I should edit these MIDIs in Windows.
All suggestions welcome. I know others have also had this problem and I have suggested that perhaps the pedal solenoid needs be adjusted. This is not the case.
Carol Beigel
