ecomp files with tracknames
2019-08-10 by Spencer Chase
i added meta data to the newer e-comp files so it will display in players such as van bascos. these files are similar to the ones i did of the earlier e-comps. if you want to convert the file names to long file names with the meta data in the file name, you can use my renameastrack program on the download page of my web site to rename the files. the titles are the original ones from the internal title text event. the composers have all been reduced to last name only to save space in the long file name. the pianist has been switched to last, first from the first last format of the original files. this has been done to make it easier to find different versions of the same work using the long file names.
you can also use my keywordto excel program to make an excel spreadsheet from these files that contains links to play them from the excel sheet using the default MIDI player.
here are links to both the older files and the newer ones.
Best regards, Spencer Chase
67550 Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
Spencer@...
Spencer@...
Spencer@...
http://www.spencerserolls.com
http://www.poodlex.com
(425) 791-0309
(707) 223-8212
Re: [disklavier] ecomp files with tracknames
i got the case of one letter in the links wrong. these should work
Spencer@...
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
------ Original Message ------
From: "'Spencer Chase' lists@... [disklavier]" <disklavier@yahoogroups.com>
Sent: 8/9/2019 10:29:05 PM
Subject: [disklavier] ecomp files with tracknames
Garberville, CA 95542 Postal service only..
Spencer@spencerserolls.com
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
2019-08-10 by Dmitry
Respect!
On Sat, Aug 10, 2019 at 3:46 PM 'Spencer Chase' lists@... [disklavier] <disklavier@yahoogroups.com> wrote:
Spencer@...
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
Garberville, CA 95542 Postal service only...
Spencer@...
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
