> On Aug 9, 2019, at 12:33 AM, 'Spencer Chase' lists@... [disklavier] <disklavier@yahoogroups.com> wrote:
> i agree that the cake 6 and 9 are probably the best for editing solo MIDI piano and a lot more complicated files as well.
> be warned that cakewalk will not edit the XP data in files.
> Best regards, Spencer Chase
> 67550 Bell Springs Rd.
> Garberville, CA 95542 Postal service only..
> Laytonville, CA 95454 UPS only.
> Spencer@...
> Spencer@...
> Spencer@...
> http://www.spencerserolls.com
> http://www.poodlex.com
> (425) 791-0309
> (707) 223-8212
> ------ Original Message ------
> From: "'Sheldon H. Deluty, M.D.' mdshd@... [disklavier]" <disklavier@yahoogroups.com>
> To: disklavier@yahoogroups.com
> Sent: 8/8/2019 7:37:44 PM
> Subject: Re: [disklavier] Midi Editing - CAKEWALK HOME STUIO
>> Good Evening:
>> The best real time Windows based midi editing programs for the Disklavier I have found over the 25 plus years I have owned my piano are the legacy programs Cakewalk Home Studio 6.0 and/or 9.0
>> Personally, I think 6.0 is superior to 9.0 because its "primitive" graphics and simplicity of design make it even more ideal as a real time midi editor for the Disklavier
>> These programs will install and work on any windows OS - even Windows 10 - as long as the OS is 32 bit (not 64 bit). They probably work best on XP, Vista or 7 (but it has to be a 32 bit OS)
>> Cakewalk 6.0 on a legacy laptop connected by an "M-Audio" USB interface to the midi input of the DKC-850 visualizes all the channels in real time and allows real time manipulation of channels, tracks and other midi parameters
>> You can save as type 0 or type 1. You can see pedal data in real time on an event list. You can see musical staff and you can even back-generate sheet music from any midi file. As I said, it is almost as if these programs were custom made for the Disklavier
>> I wish Yamaha would resurrect these legacy programs and offer them with the pianos - it would make editing so much easier for so many users
>> It is best to get an old legacy windows laptop (XP or 32 bit 7) and install cakewalk and it becomes a dedicated midi editor for the Disklavier
>> It is really a shame that there is no current program I have been able to find which has the simplicity and elegance of cakewalk for the Disklavier
>> These legacy programs occasionally come up on ebay - grab them if you can (they require a serial number for installation) - unfortunately Gibson bought Cakewalk several years ago, ran it into the ground and Cakewalk now no longer exists as a company, so you cannot purchase these programs any longer from the company
>> I hope this information is helpful to the Disklavier community
>> Sheldon Deluty
>>> On 8/8/2019 9:17 PM, Ian wam@... [disklavier] wrote:
>>> Carl,
>>> the XP format works fine for me in playback on my Mac thru older Standard Midi Editors and players. The extra info seems to be ignored by those Apps but the Pro pianos seem to read the XP content regardless.
>>> I notice that Steinway provides an Editor in an iPad with their recording version of the Spirio.
>>> DOES ANYONE KNOW OF A YAMAHA DESIGNED EDITOR?
>>> Their site offers a lot of obscure technical Apps but not a basic Editor. Yamaha were using Zenph to create the e-Competition files. I have Zenph for Mac, which I bought in 2002, but all the Zenph files and apps were sold to Steinway and withdrawn from the general market.
>>> So, DOES ANYONE HAVE ZENPH FOR WINDOWS? – because I have friends with Disklaviers using Windows – and it is perfect for optimising files for many different Yamaha Disklaviers and will convert to and from XP, Pro, MkIV, III, II etc..
>>> Ian
>>>> On 09/08/2019, at 5:54 AM, 'carlspost2@...' carlspost2@... [disklavier] wrote:
>>>> That's great news Spencer.
>>>> Thank you so much.
>>>> I understand that the xp format has more information in it, but is it correct that they will work fine on older disklaviers without any difference between the standard files?
>>>> Carl
>>>> On Friday, 9 August 2019, 12:53:19 am AEST, 'Spencer Chase' lists@spencerserolls.com [disklavier] <disklavier@yahoogroups.com> wrote:
>>>> i had some time with a fast internet connection so i got all the 2013 to 2018 ecomp files in XP format where available and std MIDI when not available as XP. i will process them adding meta data in a consistent format and will let the group know when i post them to my web server.
>>>> Spencer@spencerserolls.com
>>>> Spencer@...
>>>> Spencer@...
>>>> (425) 791-0309
>>>> (707) 223-8212
>>>> From: "'Spencer Chase' lists@... [disklavier]" <disklavier@yahoogroups.com>
>>>> Sent: 8/8/2019 7:18:54 AM
>>>> Subject: Re[2]: [disklavier] Search midi files by track Info?
>>>>> if there is a way to bulk download them all after 2011 i can do it myself. i remember that getting the earlier ones required multiple downloads and that i could not figure out how to get a download manager to do it. maybe it is easier now?
>>>>> also is there any reason to get a different format than the XP files? they work on my LX, do they work for everyone?
>>>>> i looked at a a sample of the 2013 files and it does look like the meta data should be easy to extract but it also look like the data entry was sloppy with many errors.
>>>>> Garberville, CA 95542 Postal service only...
>>>>> Spencer@...
>>>>> Spencer@...
>>>>> (425) 791-0309
>>>>> (707) 223-8212
>>>>> From: "Spencer Chase lists@... [disklavier]" <disklavier@yahoogroups.com>
>>>>> Sent: 8/8/2019 6:40:04 AM
>>>>> Subject: Re: [disklavier] Search midi files by track Info?
>>>>>> Might be good to start with a few samples from each year to see how consistent the formatting is of the text events. Then we can figure out how to send them. I have a satellite internet which is not great for receiving large amounts of data
>>>>>> On August 8, 2019 2:03:27 AM MST, "'carlspost2@yahoo...com.au' carlspost2@... [disklavier]" <disklavier@yahoogroups.com> wrote:
>>>>>> Hi Spencer,
>>>>>> Thank you for your response.
>>>>>> Actually I have already sent you an email in regard to this so forgive the double up if you discover the duplicated message.
>>>>>> Your e-piano comp files have been just wonderful. Especially in my teaching when I am able to quickly search for a particular piece of music and getting it playing on the Disklavier.
>>>>>> I am happy to help you update your midi files. If you are happy to add the meta date etc to the file names I will send you all the files.
>>>>>> It may take a bit of time but I will try my best to get them to you.
>>>>>> Sound like a fair deal? :)
>>>>>> Cheers,
>>>>>> Carl
>>>>>> On Thursday, 8 August 2019, 03:38:23 pm AEST, 'Spencer Chase' lists@... [disklavier] <disklavier@yahoogroups.com> wrote:
>>>>>> i have all of the e-comp files up to 2011 with meta data as keyworded text events and track names as composites of title composer and performer. i also have tag.txt files for these which can be used with mid2pianocd. i had to download the meta data from the web site and insert it into the files because the earlier stuff did not have this data in the files. it looks like the 2017 files might have this data which would make it much easier to add the data in a consistent format as i did with the older files. i donot want to take the large amount of time needed to download all of these files but if someone will send them to me i can add the text events and track names to the post 2011 files. i think that i formatted the text events so the data shows up in van bascos.
>>>>>> Spencer@...
>>>>>> Spencer@...
>>>>>> Spencer@...
>>>>>> (425) 791-0309
>>>>>> (707) 223-8212
>>>>>> From: "carlspost2@yahoo.com...au [disklavier]" <disklavier@yahoogroups.com>
>>>>>> Sent: 8/7/2019 4:24:09 PM
>>>>>> Subject: [disklavier] Search midi files by track Info?
>>>>>>> Hi All,
>>>>>>> I have a large number of midi files that are saved using abbreviated titles.
>>>>>>> However, in the actual midi file themselves there is a lot of other information regarding the name of the music and performer etc.
>>>>>>> These include files available from the e-piano-competition (http://www.piano-e-competition.com/midi_2017.asp)
>>>>>>> For example, the attached file is named "CaoJ01.mid " however, the detail are found as text events within the file:
>>>>>>> text_event 0 Title: Prelude and Fugue in D Minor, WTC II, BWV 875
>>>>>>> text_event 0 Composer: Johann Sebastian Bach
>>>>>>> text_event 0 Performer: John Cao
>>>>>>> My question therefore is this: is there a program that allows one to search multiple files based on information within the file..... or is there a quick way to rename the files using the text event info.
>>>>>>> At the moment I have no way of storing the many (100's) of midi file in any logical order.
>>>>>>> Many Thanks!
>>>>>>> Carl
