> Hi
> The order of the songs are stored in the pianodir.fil file. Delete that file and you will loose the info that is displayed, ie Disk name artist and each song title.
> But yes you will be able to rename the files into any order you like.
> Midi Magic
> --- In disklavier@yahoogroups.com, "dsmith941" <dsmith941@> wrote:
> > I think I finally got the method. After RipARooter, I delete the pianodir.fil file. Then sometimes the song files have no suffix, eg, no .fil. So I add it and add a prefix to order the songs 001 song1.fil, etc..Then onto the thumb drive in folders. Lots of busy work but I guess only hve to do it once. Thanks. Dave
> > --- In disklavier@yahoogroups.com, "Carol Beigel" <thecarolb@> wrote:
> > > I copied each floppy into a folder named the serial number of the disk, i.e.
> > > 501234, etc. on my ard drive. I thought the piano files were named
> > > something like Piano01, Piano02, etc. in each folder. Then again, I used
> > > the DVK utility to do this in the first place along with Geibler. Are we
> > > talking alphabetical order of each disk or the entire project?
> > > Carol
> > > ----- Original Message -----
> > > From: "dsmith941" <dsmith941@>
> > > To: <disklavier@yahoogroups.com>
> > > Sent: Friday, July 30, 2010 2:17 PM
> > > Subject: [disklavier] Re: Getting my Yamaha Floppy disk library onto the
> > > DKC-850
> > > > Carol, I have been using the usb thumb drive to transfer floppies using
> > > > RootARipper. It always reorders the song into alphabetical order, which
> > > > is maddening. Is there a work around to keep them into the original disk
> > > > order?
> > > > Dave
> > > >> You have several options.
> > > >> 1) load the floppys into the flash memory of the DKC-850
> > > >> 2) use RootARipper (software utility found at www.carolrpt.com) and copy
> > > >> each floppy to a hard drive on your computer. Each floppy could have
> > > >> it's
> > > >> own folder. Then use a disk burning software program and burn these
> > > >> folders
> > > >> to data CD.
> > > >> 3) or copy these folders to a USB thumb drive
> > > >> THE DKC-850 will read MIDI files or ESEQ or .FIL files copied to the root
> > > >> directory or one level down (folder). Make sure nothing else is on the
> > > >> CD
> > > >> or the thumb drive.
> > > >> Depending upon how much music you have, and the flash drive is only 4
> > > >> M(?),
> > > >> you could organize your music into folders then burn them to CD or USB
> > > >> thumb
> > > >> drive. You could have a CD for jazz, another for Mozart, another for
> > > >> showtunes, etc.
> > > >> Carol Beigel
> > > >> Sent: Tuesday, July 13, 2010 8:20 PM
> > > >> Subject: [disklavier] Getting my Yamaha Floppy disk library onto the
> > > >> DKC-850
> > > >> >I imagine this has already been asked and answered, but 30 minutes of
> > > >> >searching the archives just confused me. So, I have just upgraded my
> > > >> >Mark
> > > >> >III to DKC-850. Is there any easy way to get my many Floppy disks from
> > > >> >Yamaha onto this new system? Is a usb floppy drive the only way. But
> > > >> >as I
> > > >> >recall, you cant read a yamaha disk anyway. The DKC-850 manual does
> > > >> >not
> > > >> >even recognize that this might be desired?!!!!
> > > >> > So, can someone please re-reply with suggestions, as this is probably a
> > > >> > question lots of people will have in the next few weeks, as the DKC-850
> > > >> > boxes are installed in the USA>
> > > >> > Thanks again for your help..... Dave
> > > >> > To Post a message to the group, send it to: disklavier@
> > > >> > To Post a private message to Todd Muncy, the group's founder and
> > > >> > moderator, send it to:
> > > >> > disklavier-owner@
> > > >> > To reach our group's web site go to:
> > > >> > http://Yahoogroups.com/group/disklavier
> > > >> > THINKING OF LEAVING THE GROUP?
> > > >> > If you are thinking of unsubcribing because you are getting too much
> > > >> > mail,
> > > >> > go the the web site and change your email delivery option instead.
> > > >> > That
> > > >> > will fix the problem, while maintaining your access to the group. If
> > > >> > you
> > > >> > insist on leaving us completely send a blank email to:
> > > >> > disklavier-unsubscribe@
> > > >> > Know someone who wants to join? Have them send a blank email to:
> > > >> > disklavier-subscribe@ or give them this link:
> > > >> > http://Yahoogroups.com/group/disklavier/join
> > > >> > Yahoo! Groups Links
> > > >> > Internal Virus Database is out of date.
> > > >> > Checked by AVG - http://www.avg.com
> > > >> > Version: 8.0.406 / Virus Database: 271.14.151/2987 - Release Date:
> > > >> > 7/7/2010 6:36 AM
> > > > disklavier-owner@
> > > > If you are thinking of unsubcribing because you are getting too much mail,
> > > > go the the web site and change your email delivery option instead. That
> > > > will fix the problem, while maintaining your access to the group. If you
> > > > Yahoo! Groups Links
> > > > Version: 8.0.406 / Virus Database: 271.14.151/3029 - Release Date:
> > > > 7/26/2010 6:36 AM
