Help w/Disklavier Selection
2011-04-13 by William
I was ready to 'pull the trigger' on buying a used Disklavier and then I ran into some discussion about 500ms delays and timing issues. So here I am, hat in hand, looking for advice. My needs are for a piano to intergrate into a number of instruments that I have. I have a Wicks glockenspiel, a set of Degan chimes, drum section (cymbal, three drums, and tamborine) and organ pipes. All of these are MIDI controlled from my computer. I would really like to have a piano in this ensemble and I have been considering the purchase of a Disklavier. Since this would be a major purchase I must be very sure that it will work. Do you think that a Disklavier would be appriopriate for this application.
There have been a few postings indicating that others have controlled their Disklavier with a keyboard. This says to me that a Disklavier would work in my application. But then there have been some postings that mention a 500ms delay between the receiving the MIDI signal and the activation of the driver solenoid.  This would present timing issues for my application where a half second delay would likely be very noticable.
Therefore the first consideration is determine which Disklavier is the best suited for my application. I do not envision a lot of use of the built in playback device so a floppy disk system would likely be fine.
At the present time I am looking at a MX500QADC.
Any help would be greatly appreciated. I have posted a rough sketch of my system in the Photos section.
Many thanks in advance
Bill
Re: [disklavier] Help w/Disklavier Selection
2011-04-13 by Mark Fontana
Hi Bill,
Probably all of the physical instruments you've already interfaced to
the computer via MIDI have some latency (in the tens of milliseconds)
between when they receive a MIDI event and when they actually produce
sound.  If the instruments respond to MIDI velocity as well, this delay
can vary.   The Disklavier's 500 ms delay (longer than the time required
to strike even the quietest note) exists to ensure that notes requested
at various velocities strike at the same time.  When playing the
Disklavier via MIDI from an external MIDI keyboard or organ console,
most people prefer to disable the 500 ms delay and live with the
Disklavier striking notes with varying latencies.
But since it sounds like you'll be playing prerecorded material, you
should leave the 500 ms delay enabled and instead adjust the timing of
MIDI events sent to each of your instruments to account for their
latencies relative to the Disklavier's fixed 500 ms latency.  One
approach would be to leave the piano events in your MIDI sequences alone
and shift the timing of the other instruments later by somewhere in the
range of about 450-480 milliseconds (not exactly 500 ms since we need to
account for the latency in striking the drums, chimes, etc.)
To be really precise about it, you could use a different offset for each
instrument after having measured the latency of each.  A quick way to
measure the latency is to connect both a MIDI synth and the physical
instrument to the same MIDI stream, send a couple of notes at typical
velocities while making a digital audio recording, then load the
recording into a sound editing package like Audacity and measure the
elapsed time between when the MIDI synth sounds and when the physical
instrument strikes.  Average the values measured for several strikes and
subtract the result from 500 milliseconds when applying an offset in
your MIDI sequences.
Someone ought to make a little box to insert into a wireline MIDI chain
to delay each MIDI channel separately by a configurable amount (say, up
to 1000 milliseconds in 1 ms units).  If you can find a product like
that, you could avoid having to manually adjust your sequences.
Mark Fontana
> Disklavier.  . . .
> very noticable.
Re: Help w/Disklavier Selection
Hi Mark;
What a highly lucid explanation!  I was not aware that the 500ms delay could be disabled.  Is this true for all of the units?  I am looking specifically at a MX500QADC.
Again, many thanks!
--- In disklavier@yahoogroups.com, Mark Fontana <mfontana@...> wrote:
> Hi Bill,
> sound.  I
Re: [disklavier] Re: Help w/Disklavier Selection
2011-04-14 by Mark Fontana
I think the delay can be disabled on most Disklaviers - George Litterst
(AKA "PianoBench") and other experts in this group can tell you for
sure.  But disabling this feature does not reduce the delay to zero.
You'd still get a bit of latency that depends on the MIDI velocity
level.  You might be able to find a level that happens to result in
latency matching that of your other physical instruments, though.
Mark
On Wed, 2011-04-13 at 13:40 +0000, William wrote:
> Hi Mark;
> Again, many thanks!
> > Hi Bill,
> to
> milliseconds)
> produce
> > sound.  I
> To Post a message to the group, send it to:   disklavier@...
> To Post a private message to Todd Muncy, the group's founder and moderator, send it to:
> disklavier-owner@...
> To reach our group's web site go to:
> http://Yahoogroups.com/group/disklavier
> THINKING OF LEAVING THE GROUP?
> If you are thinking of unsubcribing because you are getting too much mail, go the the web site and change your email delivery option instead.  That will fix the problem, while maintaining your access to the group.  If you insist on leaving us completely send a blank email to:
> disklavier-unsubscribe@...
> Know someone who wants to join?  Have them send a blank email to:
> disklavier-subscribe@... or give them this link:
> http://Yahoogroups.com/group/disklavier/join
2011-04-14 by Bill Brandom
Hi Bill,
The Disklavier you are considering purchasing is an MX80 system.  You cannot change the MIDI delay in timing with this system.
Bill
William <bmcgown@...> wrote:
Hi Mark;
Again, many thanks!
> Hi Bill,
> sound.  I
disklavier-unsubscribe@yahooGroups.com
Yahoo! Groups Links
