Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
seperate output levels MD ?!?!?
2004-11-06 by glennplumber
Hello,
I noticed that when i use a seperate output, the level is louder
then when i use the main output.
Does anyone know in what scale the main output level is different
from the seperate output level (meaning: output C , D etc.)
This is important for me when i want to turn the levels to be louder
or softer in the same scale.
Thanx for the 'input' ;-)
Re: [elektron] seperate output levels MD ?!?!?
2004-11-08 by Joseph Melnyk
the individual outputs are the same as the main output being cranked
all the
way up.  and the master level control only effects the A/B outputs and
doesn't
effect the C/D/E/F outputs at all.  to adjust their level, you have to
adjust the
level of the internal machine routed to them.
