Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
very strange midi behavior from the MnM
2007-05-14 by Tony Scharf
I have completely run out of ideas on this, but its driving me crazy.
If I either use the MnM to sequence external gear, or send midi data to gear
via the MnM's thru port, certain pieces of gear in my studio start to go
absolutely crazy (i.e. stuck notes, held notes cutting out, lock ups and
freezes).  What I dont get is that the MnM doesnt even have to be playing
*anything* for this to happen.  For example, if I plug my MPC1000 into the
input on the MnM, and then take the thru port into my PEK, the pek goes
crazy with cutting off notes, and its sequencer timing gets all messed up.
my TG33 and Proteus 2500 both start getting bad stuck notes.  my clavia G2
just completely looses it, locking up and playing random notes.  If i remove
the MnM from the equation, and just go straight from MPC to
PEK/TG33/P2500/G2, then all is well and I dont see this at all.
I have also attempted sequencing the PEK and G2 from the MnM.  I get the
same type of wierd behaviors then, but it seems somehow associated with
having a track in the MnM that is running an Arpegiator (internal or MIDI
track, gives the same results).
It is really baffling, and makes the MIDI tracks on the MnM effectively
useless for me.
Does anyone have any suggestions?  Ive tried changing cables, and capturing
the MIDI coming out in MIDI OX, but everything *looks* normal.  its the
strangest kind of bad voodoo ive run across in a piece of modern gear.
Tony
RE: [elektron] very strange midi behavior from the MnM
2007-05-14 by M-.-n
Hey Tony,
have you tried to use midiOx or something similar to see what the output of
the MnM was like ? Maybe it would help finding the cause.
Good luck
Marc.
Checked by AVG Free Edition.
Version: 7.5.467 / Virus Database: 269.7.0/801 - Release Date: 12/05/2007
18:40
Re: [elektron] very strange midi behavior from the MnM
I have, and it yeilds nothing.   that is what is so frustrating - I cant see
a data error.  Maybe Ill recapture the data and send it on to the list.  A
few more sets of eyes looking at it might catch something I missed.
Tony
On 5/14/07, M-.-n <nostromo@...> wrote:
> Hey Tony,
> of
> Good luck
> Marc.
> 18:40
2007-05-14 by Tim Wellens
Hey Tony,I have EXACTLY the same problem...I have a big set-up and
everything worked normal until I put my MnM in the chain...My Yamaha DX-200
regularly locks-up (midi-error) ... very strange as I have a midi-patchbay
en de MnM and DX200 have separate midi-channels/cables....
Anyone got a clue? I remember I had that problem also with V1.70 but now
with V1.80 it's more prominent....
Club Filth
>From: "Tony Scharf" <noisetheorem@...>
>Reply-To: elektron-users@yahoogroups.com
>Subject: [elektron] very strange midi behavior from the MnM
>Date: Mon, 14 May 2007 08:20:47 -0500
>gear
>remove
>useless for me.
>Tony
A lot of passions?  Collect all your personal info on one central location ,
for free! http://get.live.com/live/features
Club Filth
>gear
>remove
>useless for me.
>Tony
2007-05-15 by Tony Scharf
Tim:
I dont even have a MIDI patch bay involved - I removed that from the chain
because I thought it was the problem.
Its some small comfort that I am not the only one that is experiencing this
off behavior, and It encourages me that it may be something software side
that can be fixed.
Tonight I am going to do some extensive tests to see if I can root down what
data is causing the trouble.
Tony
> DX-200
> Club Filth
> >From: "Tony Scharf" <noisetheorem@... <noisetheorem%40gmail.com>>
> >Reply-To: elektron-users@yahoogroups.com<elektron-users%40yahoogroups.com>
> >To: elektron-users@yahoogroups.com <elektron-users%40yahoogroups.com>
> >gear
> up.
> >remove
> >useless for me.
> capturing
> >Tony
TM-1 discontinued??? Noooooooooooo!
2007-05-16 by Morris, John K
Is the TM-1 discontinued??? On the elektron website there are none
available to purchase but if you try to add it to your cart anyways, it
says the product is discontinued.  Is this true or are they just out of
stock at the moment?
Re: [elektron] TM-1 discontinued??? Noooooooooooo!
2007-05-16 by Tarekith
I think it's an error.  It said that once before a few months ago too,
but Daniel said it was definitely not discontinued.
Tarekith
http://www.tarekith.com
2007-05-24 by hymen_blaster
Hey I have this SAME problem. I've tried a couple of midi interfaces
(emagic AMT-8 + MOTU Midi Express XT), a couple of different
patching programs (Midi-OX, Unitor Control, a DAW) and even found it
when connecting the MNM to other things directly.
There are some other issues, too. When slaved to external sync,
pressing stop on my sequencer only stops the monomachine for a
minute or so, at which point it amazingly decides to start playing
back by itself. It is NOT that voices are sustaining - the entire
sequencer just magically starts by itself. It does this even after
a "double stop" on the mnm.
--- In elektron-users@yahoogroups.com, "Tim Wellens" <timwel@...>
Yamaha DX-200
patchbay
but now
> Club Filth
crazy.
data to
> >gear
start to go
ups and
playing
into the
pek goes
messed up.
clavia G2
If i
> >remove
get the
associated with
or MIDI
effectively
> >useless for me.
capturing
its the
gear.
> >Tony
location ,
2007-05-25 by dekengren
I have this problem too, but it isn't the entire sequencer I believe,
it seems to be single tracks or arpeggio tracks or something that
starts after a little while. Are you guys saying it is worse in the
latest OS v1.08? In that case I might skip upgrading and wait for
Elektron to fix it.
