no its just a tswitching transistor and a step up
transformer
the transistor switches like a square wave 0-5
volts theres some smothing caps that makes it a small sin signal this signal
then is turned into a high voltage ac with very low current via a step up
transformar because the signal is a magnitised through the coils via inductance
the windings pick up this ac sin signal then transforms it to a biger
signal
the reason for whinning when the efoil dies is
bigger resistance and the transformers windings can become lose
but when no efoil is connected it has no load so is
an open circuit
you can do away with it as it serves no perpose i
always remove them when fitting an oled
also on racks i also remove the angle circuits
as the capaciters are being charged but not
discharged as they are open circuit no load
Sent: Monday, February 17, 2014 8:39
PM
Subject: Re: [emax] Diagnosing
non-functional Emax
I will check those voltages when I get home this evening. Here's
a theory:
I replaced the LCD with an OLED about 6 months ago. I never removed the
inverter from the CPU board. Is there a chance that the inverter fried itself
by not having a load (EL backlight) to drive?
I will try removing the inverter as it's obviously not necessary with an
OLED display.
-Dave
No virus found in this
message.
Checked by AVG - www.avg.com
Version: 2014.0.4335 / Virus
Database: 3705/7100 - Release Date: 02/17/14
