Emax
Emax 2 won't recognise Zip100 drive
2014-05-10 by Dave Whelan
Hi all
I’ve just acquired an Emax 2 rack (2213) and I’m trying to connect a SCSI Iomega 100 zip drive. On the back of the drive I have switched the ID to #5 and it is an ‘auto detect’ 25 pin interface so I presume that does away with the need for a termination switch??
Anyway, it’s connected to the SCSI port on the back of the Emax and when I choose to format a disk I can select drive #5 and the display will show IOMEGA ZDRIVE but then when I try to format the disk, it says ‘MEDIA ERROR’. Also, if I use the drive select button, it says it is not an Emax 2 drive.
I have searched and searched for answers but to no avail. I know the Zip disk is already Emax 2 formatted. Does it matter that the Zip lead is auto detect?
Any answers would be REALLY appreciated.
Re: [emax] Emax 2 won't recognise Zip100 drive
2014-05-10 by Ted Summers
Are your disks new?
If not- I recommend getting some especially where you are testing.
You may also need a new DB25 cable, a bad one can result in odd behavior.
The Zips with auto-select do terminate.
You shouldn't be changing the ID of the Zip drive once it's powered on.
You also can't change the SCSI id # of the drive once Emax is booted.
I assume you are:
setting the ID
turning the drive on
inserting the disk
Then turning on the Emax, booting from floppy… now formatting
What version of software are you using?
-T
On May 10, 2014, at 5:24 AM, Dave Whelan jersey69tvx@... [emax] wrote:
Hi all
Re: Emax 2 won't recognise Zip100 drive
2014-05-11 by ismypassionmusic@...
Do not turn on the drve while the emax is powered, doing so can damage your emax.
always power your external scsi device before switching on your unit.
i would suggest switching on the terminator on your zip drive, if it still fails try another disk in your zip.
what zip model are you using?
2014-05-12 by jersey69tvx@...
I think I may have fried the drive. I got another one this morning. An Iomega zip100 model no. Z100S2 and I've set the rear switches to term: on and id:#5. This drive will read and load presets from a couple of emax sound library zip disks great. Problem solved??....
Not quite. My second problem is still happening. When I try to format a Zip disk (in this case, a brand new mac formatted zip100 disk), I select Master 5, select drive #5, insert disk and confirm format request but then the drive does nothing and the Emax displays the message "MEDIA ERROR!" I have tried a couple of disks but get the same message.
Does anyone know where I am going wrong??
