Emax
Emax II / MIDI Controller Setup Question (newbie)
2003-08-09 by jamiefillmore
Hi I'm new to the group... and already have a (probably) dumb
question. Didn't find this particular question in searching.
I have an Emax II and a Roland AX-7 (MIDI Controller). I'm trying to
set them up to play nice together. Out of the box the Controller
will play the Preset I have selected/loaded on the Emax. However, I
can't get the Controller to make the Emax change presets.
I suspect I need to understand the relationship between MSB and LSB
numbers (which the Roland manual references) and whatever the
equivalent is on the Emax side... then I will need to program the
controller to use that information accordingly.
Thanks for any hints or information (even if only to suggest a
reference I should go check out).
All best,
j
