Emax
Re: [emax] Digest Number 626
2004-04-27 by steven cook
Yes, i updated both my emax's using the Emax Utility
program.
do u think that it loaded the OS wrong?
hmm that could be the problem
thanks for any help.
Stephen
Message: 4
   Date: Tue, 27 Apr 2004 12:41:14 +0200 (CEST)
Subject: Re: Digest Number 625
OK for your Emax os version but did you upgrade it
using Emax utility? I must now it: the problem has
occured after using it for me.I will check my Emax
tonight to verify how to proceed. I'm a bit long to
answer because I don't have the web at home. For now,
i'm still an Atari ST addict..!
See you!
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
http://hotjobs.sweepstakes.yahoo.com/careermakeover
2004-04-29 by Sylvain Dumortier
Stephen, as I told you before, the problem with Emax's
sequencer has occured after upgrading it using
Emaxutil for me. My Emax was a HD model with an OS HD
1.1 version. I upgraded it to SE first and then to
Plus and when I tried to use the Supermode utility to
have the 16 part multitimbrality, I had the same
problem than you: Please insert Disk... and crash.
First, I tried to boot my Emax with a HD 1.1 floppy
and the sequencer was back again. Then, I decided to
install everything from scratch one more time and now
it's OK. Follow each step carefully using E-MU SE
Upgrade Instructions. (That's available on the net).
Good luck!
 But be sure that if your floppy drive is OK to load
sounds, it can't be broken. Electronic stuffs are not
esoterics: it's OK or it's Out Of Order. It can't be
good for things and bad for others. Keep this rule in
mind.
See you!
Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
Cr\ufffdez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
Dialoguez en direct avec vos amis gr\ufffdce \ufffd Yahoo! Messenger !T\ufffdl\ufffdchargez Yahoo! Messenger sur http://fr.messenger.yahoo.com
