Emax
Se upgrade failure 2
2004-05-28 by franceslengel
Hello there,
After another 4 hours of problem solving I still haven't cracked it!
How hard can this be! I am starting to think now that I would rather
pay a list user that has cracked it to make me a emax disk than waste
anymore time but just incase I am doing something really dumb and
obvious - or if this is of any help to others:
here is 2 methods I tried - both failed:
1st attempt *Disk method.
1. formatted disks on emax, put emaxutil + setup.em1 on Dos formatted
disks.
2. took to Win 3.1 PC. and quit win to DOS.
3. loaded emaxutil disk and read setup.em1
4. then tried to write to emax format disk
Result: Emaxutils could not write image to disk - file not read.
2nd attempt. HD method.
1. as instructions said, transferred both emaxutil + seup to C: drive
2. exited win 3.1 to dos and loaded emaxutils.
3. write seup.em1 to disk - goes through process this time! writing
to 90 (or something) with head counter fluctuating between 0 + 1.  No
error messages, when done flips back to emaxutils title screen.
Result: after burning 3 versions of Seup.em1 and blissdsk just to
check, all disks resulted in same failure when put into emax
(coughed, spluttered and flashed lights:loading software but nothing
happens??)
Any HELP? Or can someone in the UK just send me a disk PLEASE!
(can pay for it - am losing patience quickly for DIY method)
Thanks a lot,
Luke
Re: [emax] Se upgrade failure 2
2004-05-28 by elmacaco
Aren't there some emax's that you can't upgrade?
  To: emax@yahoogroups.com
  Sent: Friday, May 28, 2004 11:59 AM
  Subject: [emax] Se upgrade failure 2
  Hello there,
  disks.
  happens??)
  Thanks a lot,
  Luke
  http://www.silveriafamily.com
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    http://groups.yahoo.com/group/emax/
    emax-unsubscribe@yahoogroups.com
  Outgoing mail is certified Virus Free.
  Checked by AVG anti-virus system (http://www.grisoft.com).
  Version: 6.0.680 / Virus Database: 442 - Release Date: 5/9/04
RE: [emax] Se upgrade failure 2
2004-05-28 by Rob Keeble
If anyone on the list would like an Emax SE upgrade diskette that absolutely
works for sure, please contact me at info@...
Emax HD users, will also need an SE HD OS disktte which I will include. So
let me know if you have a HD model.
Yes I do make a nominal charge, but then I do have to buy diskettes and mail
them out via air mail (unless you are in the UK, then its even cheaper!).
However the upgrade works first time, so you don't waste time playing with
EMX or writing emails.
All Emax's can be upgraded to SE, except those that have a faulty diskette
drive...Check you can read samples before upgrading..
Rob
www.emulatorarchive.com
    Thanks a lot,
    Luke
