I think you need to get it repaired or replaced.
Bob
--- blakbeltjonez <blakbeltjonez@...> wrote:
> i have recently run into the same problem with my
> Emax/IKE - it worked fine
> when i first got it, but now whenever i sample
> anything i get a lot of noise, no
> matter what sample rate or gain setting i use.
> in addition, when i am on the VU page, i get a
> strange repeated high pitched
> square wave-ish rising tone monitoring the output -
> which happens whether
> the volume is up or down on the Emax! this happens
> whether or not i have a
> 1/4" cable plugged into the sample input.
> i suspect i have a flaky A/D converter but i don't
> have any way that i know of to
> check (don't think the diagnostics do that, not as
> far as i could tell. already
> recalibrated everything there was to do).
> if someone knows what's happening, i would
> gratefully appreciate the insight
> --- In emax@yahoogroups.com, Bob Conner
> <rennocbob@y...> wrote:
> > I'm guessing the source sounds fine when you
> monitor
> > it?
> > Also that you have swapped out all audio cables,
> tried
> > adjusting line levels in, tried adjusting the line
> out
> > volume, tried listing to the sample though a
> different
> > Emax output, tried listing to the sample though a
> > different amp/head phone, checked your sample
> > settings, tried sampling at a different rate, and
> have
> > eleiminated a bad plug on any patch bay, mixer
> (and
> > levels), outboard effects?
> > Checked for ground loops?
> > Does this happen when you sample something else?
> > Bob
> > --- mkragab <mkragab@y...> wrote:
> > > Hey if you're reading this, Thank you!
> > > I've had my Emax rack for a month, so I'm just
> > > getting familiar with it. Just yesterday I
> > > sampled some drums into it @ 28khz and it
> sounded
> > > fine. About 15 minutes later I
> > > sampled something the same drum loop and it was
> way
> > > noisy... alot of fuzziness to the
> > > sound. I noticed that the noise is increased
> > > inbetween transients and it happens with
> > > everything I sample from that point forward.
> Can
> > > anyone explain why this is happening?
> > > I'm thinking if it's the power supply.....
> > > somebody respond please!!!! I know you're out
> there,
> > > I get the emails..... just not when it
> > > comes to my posts....
> > > Thanx, MKR
> > __________________________________
> > Yahoo! Messenger
> > Show us what our next emoticon should look like.
> Join the fun.
> http://www.advision.webevents.yahoo.com/emoticontest
Do you Yahoo!?
Plan great trips with Yahoo! Travel: Now over 17,000 guides!
http://travel.yahoo.com/p-travelguide
