Emax
Emax II Inverter Question
2005-04-06 by Daniel J Litwin
Got a problem with my Emax II:
LCD was dim, so ordered a new foil for the backlight.
Display was lit up fine prior to replacment.  My synth tech resoldered
the new foil to the LCD PCB.
I replaced the LCD PCB back in the emax and reassembled.  LCD works
fine, EXCEPT no backlight.
What could be wrong?  Would my inverter have gone?  If so, how can I
verify?  I don't know where it is located in the Emax II.
I did specify the synth was an Emu Emax II.  Foil ordered from Telesis.
Dan
Re: [emax] Emax II Inverter Question
2005-04-06 by Humberto Fierro
Hi !
probe your conection before install all together. you can probe only the backlight without connecting the data bus lines and change the polarity. The best thing is sense the voltage with voltmeter ever!
also could be that with the handling you can broke one line !
Dan
http://www.silveriafamily.com
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/emax/
emax-unsubscribe@yahoogroups.com
Do You Yahoo!?
Yahoo! Net: La mejor conexión a internet y 2GB en tu buzón de Correo Yahoo! por $100 al mes.
2005-04-06 by ted Summers
FYI-
If anyone needs an Emax II LCD I have 2 brand new ones (with gold pins,
not soldered on the displays yet) That are exact replacement. Can be
modified to fit in Emax I also.....
Ted
On Apr 5, 2005, at 7:06 PM, Humberto Fierro wrote:
> Hi !
> Dan
> Do You Yahoo!?
