Board swapping
2005-09-15 by bishop1973ar
Hi, I read some old messages concerning board swapping between an Emax 2 rack and a keyboard. I have a 2mb KB and a 8mb rack and i'd like to have them the other way around. Can anybody give me some advice ? Thanks, Diego
2005-09-16 by J R
Switch out both boards in both machines, not just the daughter/upgrade board. I had the same situation and it didn't work by just switching the daughter boards. They fit rack and keyboard. I did have an odd problem with sampling after. The key position got transposed somehow and everything I sampled was out of tune and had to be transposed up. I don't know if it's the keyboard controller interface or what but it was a pain and took some hard thinking to figure out what was going on. GOod luck! --- bishop1973ar <dhpb@...> wrote: > Hi, > > I read some old messages concerning board swapping > between an Emax 2 > rack and a keyboard. I have a 2mb KB and a 8mb rack > and i'd like to > have them the other way around. Can anybody give me > some advice ? > Thanks, > > Diego > > > __________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com
2005-09-16 by bishop1973ar
J R, Thanks for your advice and for answering my mail too. I swapped all the boards (CPU + daughter and analog output), except the display/buttons board which is incompatible. After the swap i got this: At the first power on all lights turn on, including the FD one and the LCD displays a horizontal black "bar" in the bottom row. If i turn off and on, only two of the three "normal" lights turn on, there is no LCD output and the FD light turns on too. Thanks, Diego --- In emax@yahoogroups.com, J R <bjbearorl@y...> wrote:
> Switch out both boards in both machines, not just the > daughter/upgrade board. I had the same situation and > it didn't work by just switching the daughter boards. > > They fit rack and keyboard. I did have an odd problem > with sampling after. The key position got transposed > somehow and everything I sampled was out of tune and > had to be transposed up. I don't know if it's the > keyboard controller interface or what but it was a > pain and took some hard thinking to figure out what > was going on. > > GOod luck! > > --- bishop1973ar <dhpb@c...> wrote: > > > Hi, > > > > I read some old messages concerning board swapping > > between an Emax 2 > > rack and a keyboard. I have a 2mb KB and a 8mb rack > > and i'd like to > > have them the other way around. Can anybody give me > > some advice ? > > Thanks, > > > > Diego > > > > > > > > > > > __________________________________ > Yahoo! Mail - PC Magazine Editors' Choice 2005 > http://mail.yahoo.com
2005-09-16 by J R
Oooh, be careful, I shorted out an Emax 2 motherboard by forcing a SCSI Zip drives connector the wrong way without looking from the back. Those motherboards are way easy to blow. I'm not sure of what the lights mean, there is an emu diagnostic paper floating around that tells you what some of the startup lighting means. I will try to look for it, that's how I determined how I fried my scsi controller. The emax displays certain lights full 'on' upon startup when something goes wrong. I'll try to find this documentation. Post to the board and ask for it in the meantime since someone else may have it handy. --- bishop1973ar <dhpb@...> wrote: > J R, > > Thanks for your advice and for answering my mail > too. I swapped all > the boards (CPU + daughter and analog output), > except the > display/buttons board which is incompatible. After > the swap i got > this: > > At the first power on all lights turn on, including > the FD one and > the LCD displays a horizontal black "bar" in the > bottom row. If i > turn off and on, only two of the three "normal" > lights turn on, there > is no LCD output and the FD light turns on too. > Thanks, > > Diego > > --- In emax@yahoogroups.com, J R <bjbearorl@y...> > wrote: > > Switch out both boards in both machines, not just > the > > daughter/upgrade board. I had the same situation > and > > it didn't work by just switching the daughter > boards. > > > > They fit rack and keyboard. I did have an odd > problem > > with sampling after. The key position got > transposed > > somehow and everything I sampled was out of tune > and > > had to be transposed up. I don't know if it's the > > keyboard controller interface or what but it was a > > pain and took some hard thinking to figure out > what > > was going on. > > > > GOod luck! > > > > --- bishop1973ar <dhpb@c...> wrote: > > > > > Hi, > > > > > > I read some old messages concerning board > swapping > > > between an Emax 2 > > > rack and a keyboard. I have a 2mb KB and a 8mb > rack > > > and i'd like to > > > have them the other way around. Can anybody give > me > > > some advice ? > > > Thanks, > > > > > > Diego > > > > > > > > > > > > > > > > > > > __________________________________ > > Yahoo! Mail - PC Magazine Editors' Choice 2005 > > http://mail.yahoo.com > > > __________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com
