Emax
clock out on the emax
2006-04-05 by joechatman1122
Has anyone had any luck or problems with using the clock out on an EMAX
to trigger a piece of analog gear, I.E. Sequential Circuits Pro1- I
plug the clock out into the CV in and get nothing. Are these two jus
incompatible, or is there something I could be doing wrong, note I have
used a TR606 to clock the pro 1- thanks for your help
joe bear
Emax SE HD OS problem
2006-04-05 by ted Summers
I have an Emax SE keyboard. I found a "non-working" emax rack HD on
ebay.
Exterior not in too good shape as it was further damaged in shipping.
Fuse holder missing - no wonder it "doesn't turn on" according to
seller.
Hard Drive is dead (multiple blinks- I have seen this before in old
macs), and system hangs on Diagnostics. This is fine so far.
I want to make my Emax SE keyboard an SE HD. It has a PC333 board.
I have 2 of the miniscribe 20MB drives that are known working.... I
have a brand new SCSI 5380 chip.
So I drop in IC13 and IC49 from the rack board. Install the SCSI
5380, and cabling. Install known good HD.
I can boot normal SE1.1 OS disk.
Floppy drive is NOT bad- it is brand new, as I put it in recently (I
know how to change the ID0 on new drives to work in emax)
I try to make an SE1.1 HD disk with EMX in DOS 6.22.
Tried formatting on Emax first, as well as formatting with EMX.
Symptom:
See "Loading Software" and hear floppy disk loading.. normal sounds -
3 times it makes the not strange loading a floppy does. Then it just
stops.
Now to the question: Is the EMX program just not properly making the
OS disk?
While I am using MS-DOS 6.22, does the PC speed have anything to do
with a successful OS creation? The PC is a 2.8Ghz P4.
I dunno if it will make a difference, but I will try on a P1/233Mhz
tomorrow at work.
Ted
Re: Emax SE HD OS problem
2006-04-26 by brainztain
I have a very similar problem.  I picked up an emax hd keyboard.
Everything turns on but I can't get it to boot.
This is what I've tried:
Making two os disks (emax hd and emax hd se, just in case) under dos
6.22 using emx.
Result: disk not formatted/loading software (stuck)
I also used emxp and a different drive ( fd-23hf with id set to 0 )
both for formatting from a computer and then for booting from the
emax... nothing.
Result: loading software (stuck)
I tried pushing the chips and pulling on them a little just to make
sure there were no old/bad connections. I also reconnected all the
cables... nothing
Result: loading software STUCK!!!!
Does anybody have any suggestions of what to do?  BTW, I tried both
ds/dd and hd floppies.
on
> ebay.
shipping.
> seller.
old
I
(I
> Symptom:
sounds -
just
> stops.
> OS disk?
do
P1/233Mhz
> tomorrow at work.
> Thanks,
> Ted
Re: [emax] Re: Emax SE HD OS problem
2006-04-27 by ted Summers
I overcame my problems.
Key info here:
if you are going to use external zip drive, you want the Emax PLUS OS
1.0 software. This allows external scsi to work.
Go to an OLD PC (like a 200MHZ or something) to make the floppy.
That is what worked for me.
If the floppy starts and does the 3 clicks, the floppy controller is
fine. The floppy controller chip is a WD1772, it is available on the
web, but I really don't think that is your problem.
Failing that, you will have to have someone send you a floppy for the
$5.....
2006-04-27 by Marco Barcena
I've actually tried making the disks on other older computers... I guess
they weren't old enough.
The only thing left to do is order an emax hd-made OS from somebody and see
if that works.
Just out of curiosity: how many people have managed to make OS disks on
modern/fast computers under DOS 6.22 or EMXP?
>From: "ted Summers" <djtbs1@...>
>Reply-To: emax@yahoogroups.com
>Subject: Re: [emax] Re: Emax SE HD OS problem
>Date: Wed, 26 Apr 2006 18:32:01 -0700
>Key info here:
>$5.....
update: just formatted 6 floppies using emx on a 233mhz computer under dos
6.22... still getting the three ticks from the floppy and then stuck on the
"software loading" screen....
>From: "Marco Barcena" <digitailslide@...>
>Date: Wed, 26 Apr 2006 20:13:35 -0700
>if that works.
> >Key info here:
> >$5.....
2006-04-27 by esynthesist
There is definitely a problem with formatting disks for EMAX samplers
on a PC (both EMX and EMXP). I've got 3 EMAX-II samplers and 1 EMAX-
SE sampler. All EMAX-II samplers can read/write EMX formatted disks,
but the EMAX-SE fails most of the time (=3 ticks).
I overcame the problem by formatting a disk on an EMAX-II and writing
the EMAXSE OS to that disk using EMXP. This works fine. But of course
you need an EMAX-II to do that :-)
What I didn't try yet is formatting a disk from the already booted
EMAX-SE and try to reboot from that disk. I'll check this.
When I have time I'll try to further investigate what causes the
incompatibility with EMAX-I sampler floppy drives. I tried some
things before (when writing the first version of EMXP) but I didn't
own an EMAX-SE that time so it was not easy to do some tests.
I think you also mentioned somewhere else that the LED of the
floppydrive is always on. I don't think that's a problem: the LED on
mine is also always on (except when power is off :-)
I also hoped to be able to solve this kind of problems for EMAX
samplers having an external SCSI interface. I was going to put a
format function for zip disks in EMXP, so that floppies would not be
required anymore. But I didn't manage to build that feature - still
trying though...
Good luck
///E-Synthesist
--- In emax@yahoogroups.com, "Marco Barcena" <digitailslide@...>
guess
and see
> if that works.
disks on
> >Key info here:
OS
is
> >$5.....
2006-04-27 by brainztain
Well, atleast now I feel more like it may just be an OS/floppy
problem and not a floppy drive or other more-serious thing.
Thanks everybody for the input!  I'll update this when/if I get this
thing fixed.
--- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote:
> For What It's worth I always used EMX with disks formatted in the
Emax I itself.  I got the plus OS to work once and since then I
haven't been able to write an OS from EMX.  Perhaps even those
without an SE /HD should try writing the Plus OS?  then once it boots
you can format floppies and possibly load other OS's?
> I do have a bunch of Emax disks with various different OS's that
all boot on my machine, so if anyone needs a particular OS I most
likely have it, the deal is still the same though.
>   ----- Original Message -----
>   From: esynthesist
>   Sent: Thursday, April 27, 2006 2:56 PM
>   Subject: [emax] Re: Emax SE HD OS problem
samplers
EMAX-
disks,
writing
course
booted
didn't
on
be
still
>   trying though...
>   Good luck
>   ///E-Synthesist
>   --- In emax@yahoogroups.com, "Marco Barcena" <digitailslide@>
computers... I
>   guess
somebody
>   and see
>   > if that works.
>   disks on
>   > >From: "ted Summers" <djtbs1@>
>   > >Key info here:
PLUS
>   OS
floppy.
controller
>   is
on
>   the
for
>   the
>   > >$5.....
>   Emax and Emax II User's Group Website
>   http://www.silveriafamily.com
>   YAHOO! GROUPS LINKS
>     a..  Visit your group "emax" on the web.
>     b..  To unsubscribe from this group, send an email to:
>      emax-unsubscribe@yahoogroups.com
>     c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
2006-04-27 by elmacaco
For What It's worth I always used EMX with disks formatted in the Emax I itself.  I got the plus OS to work once and since then I haven't been able to write an OS from EMX.  Perhaps even those without an SE /HD should try writing the Plus OS?  then once it boots you can format floppies and possibly load other OS's?
I do have a bunch of Emax disks with various different OS's that all boot on my machine, so if anyone needs a particular OS I most likely have it, the deal is still the same though.
  trying though...
  Good luck
  ///E-Synthesist
  guess
  and see
  > if that works.
  disks on
  > >Key info here:
  OS
  is
  > >$5.....
  YAHOO! GROUPS LINKS
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
