Re;HELP!
2006-06-16 by angelo_negrette
I need help figuring out what the deal is with my SE HD.Some of the display promts don't correspond to the stickers that where put on the face of the keyboard when it was upgraded to SE HD. In Master the sticker says 0- is special and 9- is restore but there is no 0- or 9- 0ption on the display. Which leads me to believe that I may need to upgrade the OS. The display says it's software version 3.1 Also- I tried following the directions for formatting the new HD from the SE upgrade manual to no avail. I can't acccess the hidden menu 9 from the Master section by choosing #9 on the key pad and I can't select the drive by holding down transpose and the drive number. I'm starting to lose my mind! I've also had no success trying to use EMX to transfer sounds or opertating systems to floppy. AAAAAAAHHHHH! -Angelo
