Emax
Replaced failing EMAX SE HD hardrive today
2007-05-24 by mikewolak
Hello,
Today I replaced the internal 20MB Miniscribe HD with a 1GB Seagate but in order for my
EMAX to boot off this HD I had to set the SCSI ID to 0.  With the EMAX Plus OS I am able to
select a different SCSI ID when the sampler is booted however from a cold boot it always
returns to 0. Is this normal? If so , how could you boot from an external zip drive if the only
ID's offered on those drives are 5 or 6? I need to hammer this out before I decide to hack an
external SCSI connector into the back of the machine.
Mike Wolak
Re: Replaced failing EMAX SE HD hardrive today
2007-05-24 by esynthesist
The EMAX-I always boots from SCSI ID 0 or floppy.
It is not possible to boot from an external ZIP drive. But you can
use an internal zip drive :-)
///E-Synthesist
--- In emax@yahoogroups.com, "mikewolak" <mikewolak@...> wrote:
> Hello,
but in order for my
> Thanks,
> Mike Wolak
Re: [emax] Re: Replaced failing EMAX SE HD hardrive today
2007-05-24 by Mike Wolak
Excellent, thanks a lot!
> But you can
> ///E-Synthesist
> wrote:
> > Hello,
> 1GB Seagate
> but in order for my
>  With the
> however from
> boot from an
> hammer this out
> > Thanks,
> > Mike Wolak
