asking about zip 100 mega implantation?!!
2008-06-23 by hvr128
hello, it's about zip implementaton on the e-max,so first how puting the new scsi,does any model can do hav the new implementation scsi?? pictures are wilkomnen! my modl is/1000 SERIAL/0974221 hier we are thank for u'r help xoxo Alf
2008-07-14 by hvr128
--- In emax@yahoogroups.com, "hvr128" <hvr128@...> wrote: > > hello, > it's about zip implementaton on the e-max,so first how puting the new > scsi,does any model can do hav the new implementation scsi?? > pictures are wilkomnen! > my modl is/1000 > SERIAL/0974221 > hier we are > thank for u'r help > xoxo Alf > i don't know! call to membr that done th scsi modification!!
for emax 1 ?? and adding hard disk external? thanx
2008-07-16 by Ted Summers
Your emax has to have SCSI support chips installed. Please go to EmulatorArchive on the web and search in Archive there for chip details. If you don't have correct chips, Emax does not have SCSI and you cannot find the chips to upgrade except by buying a broken one on ebay. Plus rather than doing HD (which old hard drive must be small and is not very reliable), I recommend to put in compact flash drive. Regards, Ted
2008-07-16 by Rv Vt
ok,but i m to weak for identify the right C-I that put th scsi option, so ,please ted watch this and tell me about..
<a href="http://fr.tinypic.com" target="_blank"><img src="http://i37.tinypic.com/xm5ylx.jpg" border="0" alt="Image and video hosting by TinyPic"></a>[IMG]http://i37.tinypic.com/xm5ylx.jpg[/IMG]
<a href="http://fr.tinypic.com" target="_blank"><img src="http://i34.tinypic.com/ix813q.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://fr.tinypic.com" target="_blank"><img src="http://i38.tinypic.com/m90z7q.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
--- En date de : Mer 16.7.08, Ted Summers <djtbs1@gmail.com> a écrit :
De: Ted Summers <djtbs1@...>
Objet: Re: [emax] scsi how update?????????????????
À: emax@yahoogroups.com
Date: Mercredi 16 Juillet 2008, 6h26
Ted
_____________________________________________________________________________
Envoyez avec Yahoo! Mail. Une boite mail plus intelligente http://mail.yahoo.fr
[Non-text portions of this message have been removed]2008-07-17 by Ted Summers
picture xm5ylx.jpg shows Revision 2 board which needs many jumpers and traces cut for SCSI to be used. If not skilled with a solder iron, should have a technician do the work or emax can be destroyed. Same picture shows IC 49 with IP344, this would need to be IP356, which is hard to get- must be gotten from a dead emax in most cases. Binary is not available to make a new one.... IC13 is showing in ix813q.jpg. It is IP349- this would need to be IP355, which is also hard to get. Same problem from above- binary not available to make a IP355 chip. Blank slot in m90ztq.jpg is where SCSI 5380 chip goes, but two chips above must be correct or just adding this chip is no good. See Emax SCSI retrofit guide at emulator archive. So in a nutshell- a) You do not have IP355 and IP356 so, no SCSI. b) Your board would have to be modified if you are able to acquire IP355 and IP356. Technically skilled persons only should attempt the modification. c) You would also need to get SCSI 5380 chip Regards, Ted
2008-07-17 by Rv Vt
ok Ted,
so i need as u said an old emax to change thoses ip 356 AND IP 355,and scsi 5380,so nice jobe,if i could find those,it 'll be ok!
regards
rv
Date: Jeudi 17 Juillet 2008, 0h34
So in a nutshell-
modification.
Ted
