Emax
No Drive Select button Emax 1 HD
2008-10-01 by David
Im used to using the Drive Select button on Emax 2 HD---on Emax 1 HD
there is none
How can disable HD and make floppy active for preset management
thanks David
Re: [emax] No Drive Select button Emax 1 HD
2008-10-01 by David
but I would have thought the OS would allow you to do this
I am running Emax 1 HD 1.1 OS
cheers Dave
On 2/10/2008, at 8:54 AM, sm papke wrote:
> hey dave, could you simply disconnection the ribbon cable to the HD?
> maybe this would work for you?
> cheers
> --- On Wed, 10/1/08, David <d2ba@...> wrote:
> From: David <d2ba@...>
> Subject: [emax] No Drive Select button Emax 1 HD
> To: emax@yahoogroups.com
> Date: Wednesday, October 1, 2008, 12:44 PM
> there is none
> thanks David
2008-10-01 by Dave Sotnick
Hi David,
The TRANSPOSE button on the Emax functions as the SCSI drive select.
Hold it down and press a number 0-6 corresponding to the drive number
you with to set it to (or unset it as your case may be).
Hope that helps,
Dave
> there is none
> thanks David
2008-10-01 by Ted Summers
Sound like you need SE Plus OS 1.0 with support for external drives....
Ted
cheers Dave
 > cheers
 > there is none
 > thanks David
