thanks --I have an external SCSI zip 100 drive how do I make it happen
I can load disks into the Emax 2 and back up to Zip 100
Can the E64 read the Emax 2 sounds on zip disk
thanks David
On 2/10/2008, at 8:53 AM, sm papke wrote:
> The E64 will not load EMAX II disks directly. I had this same
> problem with my ESI200. The specs say that these samplers are
> compatible with EMAX II libraries, but what they don't tell you is
> that they will not read the floppy disks. You will need to load them
> via SCSI (Zip100) drive or CD drive
> cheers
> --- On Wed, 10/1/08, David <d2ba@xtra.co.nz> wrote:
> From: David <d2ba@...>
> Subject: [emax] Emax 2 disks floppy backups won�t load into the E64.
> To: emax@yahoogroups.com
> Date: Wednesday, October 1, 2008, 12:47 PM
> The Emax 2 keyboard is too fragile to tour with
> Any ideas how I can get Emax library into E64
> thanks in advance
> David
> http://www.silveriafamily.comYahoo! Groups Links
