Paul,
I'm an absolute amateur when it comes to electronics. However, with
the help and guidance of this user group, I did manage replace the
burnt out power supply with a new one and it wasn't rocket science!
If you follow the thread from message #4003 you should get the whole
procedure.
Where I came unstuck was in replacing my LCD, which is why I need to
replace the button panel.
Good luck,
Alan
--- In emax@yahoogroups.com, Paul Lee <tripmastermonkee@...> wrote:
> sorry for the constant questions, but are there simple instructions
or guides for removing the power supply? is it just a matter of
unscrewing or will there be soldering involved? i've never opened my
emax up before, and i have no clue what i'm supposed to even send you.
Any info would be greatly appreciated, thanks!!
> (btw i have a rack and a keyboard, both power supplies are out)
> --- On Tue, 12/30/08, jammie.emma <jammie.emma@...> wrote:
> From: jammie.emma <jammie.emma@...>
> Subject: [emax] Re: Help My Emax won´t power on anymore...
> To: emax@yahoogroups.com
> Date: Tuesday, December 30, 2008, 3:08 PM
> --- In emax@yahoogroups. com, Paul Lee
<tripmastermonkee@ ...> wrote:
> > just need to send power supply
> jammie logan
> synth and sampler repair
> 42 Glastonbury crescent
> walsall
> westmidlands
> ds3 2rf
> united kingdom
> and if it cant be fixed then there is no charge
> > would this be something i could dissassemble and send you only the
> part that needs to be repaired? or would i need to send you the whole
> unit?
> > --- On Mon, 12/29/08, jammie.emma <jammie.emma@ ...> wrote:
> > From: jammie.emma <jammie.emma@ ...>
> > To: emax@yahoogroups. com
> > Date: Monday, December 29, 2008, 1:25 AM
> > --- In emax@yahoogroups. com, "tripmastermonkee"
> > wrote:
> > > you can send it to me but i live in the uk
> > regulators are cheap £1 and caps are cheap to
> > you need to find out how much postage is for your item to see if it
> > is worth sending it me
> > labour will be a fixed price of £30 for repairing a emax 1 and 2
> > power supply plus parts and postage
> > i am also in the design stage for a uprated more stable power supply
> > for the emax,s ill keep you posted
> > jammie
> > > @ marc -
> > > could i get a quote from you estimating the total cost of labor and
> > > parts to repair/replace the emax power supply? Any info would be
> > > --- In emax@yahoogroups. com, "jammie.emma" <jammie.emma@ > wrote:
> > > > --- In emax@yahoogroups. com, "marc" <marc_sps@> wrote:
> > > > emax2 psu wont fit yes you can send it to me and i will fix it
> > > > jammie
> > > > > i disconnected all the cables and checked the fuse on the PSU
> (looks
> > > > ok), No luck so far.
> > > > > The Emax still makes the buzzing sound when i want to power
it on
> > > > and nothing happens.
> > > > > Since it is not possible to use an PC psu, does the EMAX2 PSU
> fit ?
> > > > > Jammie...in case i won´t be able to find a replacement, could
> i send
> > > > you the PSU for fixing
> > > > > Cheers
> > > > > Marc
> > > > > > no you cannot fit a pc power supply in just fix the emax 1
> > > > > > check the internal fuses also and the psu caps check for
> > leakage if
> > > > > > your not happy fixing it your self you can send it to me
> > > > > > walsall
> > > > > > westmidlands
> > > > > > ws3 2rf
> > > > > > united kingdom
> > > > > > > I was leaving my Emax 1 HD SE out of my rack for a few
> days (was
> > > > > > getting ready to get a card
> > > > > > > reader installed) i tried power it on today
and...nothing. ..
> > > > > > > I get a buzzing sound which is probably coming from the
power
> > > supply
> > > > > > but nothing more....
> > > > > > > I am guessing that the power supply is broken. Does anybody
> > > know if
> > > > > > i can fit in an old PC
> > > > > > > power supply ? where could i get a new one ?
> > > > > > > thanks
> > > > > > > Marc
> > [Non-text portions of this message have been removed]
