Emax
Syquest EZ135......should this work with my Emax II?
2008-12-22 by bty54193247
Hello all,
I've noticed that a few people are using a Syquest EZ135 external drive, but I can't get mine
to work.
My Emax II keyboard can see the drive, but warns: 'Not an Emax II drive'.........do I have to do
anything in the keyboards settings to get the Emax II to see my drive?
I've set the SCSI ID to 4, so there shouldn't be a conflict with other drives, etc.
Any ideas......I know John is using an EZ135 without issue.
All the best
Dave
Re: Syquest EZ135......should this work with my Emax II?
2008-12-22 by rascalrevenge
Well, Emax obviously recognizes EZ-Drive, the message it shows is most
likely related to the media(disk) itself, which has some foreign data
on it I guess (?). You need to format the EZ-disk with the Emax, did
you do that ? Problem may be solved then.
I also had an Emax II working with EZ-drive, no problem.
--- In emax@yahoogroups.com, "bty54193247" <goodrobot@...> wrote:
> Hello all,
> to work.
other drives, etc.
> All the best
> Dave
Your a star!!! I was confused by the message, as I thought the message referred to the
drive itself rather than the disc I was using.
Thanks to your advice I've now managed to format the disk, and start loading my sample
banks on there.....many thanks indeed!!!
All the best
Dave
> --- In emax@yahoogroups.com, "bty54193247" <goodrobot@> wrote:
> > Hello all,
> > to work.
> other drives, etc.
> > All the best
> > Dave
Re: [emax] Re: Syquest EZ135......should this work with my Emax II?
2008-12-22 by John Silveria II
My SCSI Chain is Emax II (rack) > EZ-135 > EZ Flyer > Esi-32. The only
issues I face are I have to boot in a specific order (EZ135, Emax II,
EZFlyer, ESi-32).
The great thing about my chain is I can access both the EZ-135 with Emax
II formatted cartridges and the EZFlyer with ESI-32 formatted cartridges
through my ESI-32 so I can directly import my EMax II stuff into the
ESI-32 if I am having memory or polyphony issues with the Emax II. At
this point my Emax II is basically for drums and analogue FX stuff that
sound a lot better through the Emax II and having the three sets of
subouts in the Emax II makes isolating drum sounds way easier.
> All the best
> Dave
                      Yahoo! Messenger: EmaxJS
The Silveria Family Website and Emax and Emax II User's Group
                    http://www.silveriafamily.com
No problem, always for ya' ;-)
It was already mentioned that you'll not be able to update your RAM.
Hey you mention your Emax II has 1 MB, that's the earliest unit
shipped, therefore you may check if you have a Stereo-model there, as
these first units - and a amount of following 2 MB models - were
indeed Mono, i.e. they could NOT SAMPLE, only playback in stereo (but
there was a upgrade kit for sale). Go into sampling menu and see if
you have there two lines (for L + R) as VU-Meter, then it's a stereo
model, mono models have only one big line as VU, logically.
Alternatively (if I remember correctly, as I sold my Emax II) the
stereo model said something like 'calibrating' after I hit the SAMPLE
button. If so you may sell yours and look for a stereo-model with more
RAM. This just in addition.
Ah, just read that it's no more working, sorry to hear that.
> indeed Mono, i.e. they could not sample in stereo (but there was a
> upgrade kit for sale). Go into sampling menu and see if you have there
> two lines (for L + R) as VU-Meter, then it's a stereo model, mono
> models have only one big line as VU, logically. Alternatively (if I
> remember correctly, as I sold my Emax II) the stereo model said
> something like 'calibrating' after I hit the SAMPLE button. If so you
> may sell yours and look for a stereo-model with more RAM. This just in
> addition.
> loading my sample
> > All the best
> > Dave
is most
data
> > > > Hello all,
> > > > to work.
> drive?
> > > other drives, etc.
> > > > All the best
> > > > Dave
