Emax
6 SCSI kits available
2009-04-13 by Ted Summers
Add SCSI capability to your Non-SCSI Emax 1.
I currently have 6 kits available.
Emax logic PCB Rev (version) 2 and 3 can be upgraded. Rev 1 boards cannot be
upgraded.
A rev 3 board will require no modifications of the logic board.
A rev 2 board needs modified.
Each set of chips will be tested in my Emax to verify operation prior to
shipping.
Kit includes:
IP379a PAL
SCSI Capable EPROM (boot prom)
AM5380PC SCSI Controller
28-pin socket for the EPROM
Wire-wrap wire for the necessary modifications.
50-pin SCSI internal ribbon cable (non-terminated).
HD-capable Emax OS disk (either SE or Non-SE... please specify when ordering
in your paypal comment).
Each kit is $50.
Shipping in the US is USPS priority mail. Up to two kits is $7.25 for
shipping.
International Shipping varies.
I take paypal. djtbs1 (at) gmail.com
The kit does not include-
HARD DISK /SCSI Drive
"external SCSI adapter board" / or external connector- but external
connectors are readily available from many sources (ebay or online).
A mounting plate to mount the HD (make one from sheet metal or steel, etc) -
or a 5 1/4 to 3 1/2 in drive bay converter kit / rails may work for this
purpose also.
A power splitter - I am not including this as I have different reports as to
whether this is needed for all emax.
Some Emax units already have a power cable for a hard drive. Both of my Emax
did.
This kit has been successfully used with:
SCSI Zip
SCSI Compact Flash
SCSI hard drive
IDE CF (works via an ACARD SCSI bridge adapter.....)
The modifications are not extremely complicated.
You need to be reasonably skilled with a soldering iron to perform the
modifications.
I am not responsible for failed modifications to your logic board.
If you are in doubt as to whether you can successfully install the kit, I
will install the kit onto the Emax logic board for $100 +shipping
Installation available currently in the US only (for the time being, this
may change).
This includes:
SCSI chipset kit
Installation Labor
Verification of floppy and SCSI boot.
OS Floppy
Internal SCSI cable.
Installation for Emax Rev 2 boards only.
Working boards only.
Upon receipt of an Emax board, I will test that the board boots and appears
to work properly.
If the board does not succeed boot test, I will send it back and not attempt
installation.
In that event, money would be refunded minus the return shipping cost.
Ted Summers
Springfield, OR USA
Re: [emax] 6 SCSI kits available
2009-04-23 by emax2@...
Hello Ted,
Your SCSI upgrade totally rocks! My Emax 1 is now and EMAX PLUS. Thanks for all of the help along the way. Very straight forward modification for techy folks.
Kind regards,
Mike G
Muse Audio
www.3M79.com
To: emax@yahoogroups.com
Sent: Monday, April 13, 2009 11:27:30 AM GMT -06:00 US/Canada Central
Subject: [emax] 6 SCSI kits available
upgraded.
shipping.
Kit includes:
IP379a PAL
Each kit is $50.
shipping.
purpose also.
did.
SCSI Zip
SCSI Compact Flash
SCSI hard drive
modifications.
may change).
This includes:
SCSI chipset kit
Installation Labor
OS Floppy
to work properly.
installation.
Ted Summers
Springfield, OR USA
http://www.silveriafamily.comYahoo! Groups Links
Re: 6 SCSI kits available
2009-08-02 by rpcfender
Hi Ted
I have a Emax I with the board
Version 2
revision C
There is no 5380
IC 13 is IP255
IC 49 is IP344
Can I upgrade my Emax?
Do you have kit left?
What wiring is needed?
Thanks
Royce
> upgraded.
> shipping.
> Kit includes:
> IP379a PAL
> Each kit is $50.
> shipping.
> purpose also.
> did.
> SCSI Zip
> SCSI Compact Flash
> SCSI hard drive
> modifications.
> may change).
> This includes:
> SCSI chipset kit
> Installation Labor
> OS Floppy
> to work properly.
> installation.
> Regards,
> Ted Summers
> Springfield, OR USA
Re: [emax] Re: 6 SCSI kits available
2009-08-02 by Ted Summers
Royce-
Yes that board is upgradable.
Instructions here for the modification:
http://www.emulatorarchive.com/assets/PDF/Emax%20Plus%20SCSI%20Retro%20Instructions.pdf
I also have slim floppy converters available for $17.50.
This allows one to hook up a standard slim floppy drive.
Pics of slim floppy installed in emax here:
http://djtbs1.spaces.live.com/
Ted
On Aug 1, 2009, at 8:46 PM, rpcfender wrote:
Hi Ted
Version 2
revision C
There is no 5380
IC 13 is IP255
IC 49 is IP344
Thanks
Royce
cannot be
 > upgraded.
prior to
 > shipping.
 > Kit includes:
 > IP379a PAL
ordering
 > Each kit is $50.
 > shipping.
steel, etc) -
this
 > purpose also.
reports as to
of my Emax
 > did.
 > SCSI Zip
 > SCSI Compact Flash
 > SCSI hard drive
 > modifications.
kit, I
being, this
 > may change).
 > This includes:
 > SCSI chipset kit
 > Installation Labor
 > OS Floppy
appears
 > to work properly.
not attempt
 > installation.
cost.
 > Regards,
 > Ted Summers
 > Springfield, OR USA
2009-08-03 by dmitri
Hi
i recently found an apple g3 tower.
is there a way to use it via scsi with my emax?
d
--- In emax@yahoogroups.com, "rpcfender" <rpcfender@...> wrote:
> Hi Ted
> Version 2
> revision C
> There is no 5380
> IC 13 is IP255
> IC 49 is IP344
> Thanks
> Royce
> > upgraded.
> > shipping.
> > Kit includes:
> > IP379a PAL
> > Each kit is $50.
> > shipping.
> > purpose also.
> > did.
> > SCSI Zip
> > SCSI Compact Flash
> > SCSI hard drive
> > modifications.
> > may change).
> > This includes:
> > SCSI chipset kit
> > Installation Labor
> > OS Floppy
> > to work properly.
> > installation.
> > Regards,
> > Ted Summers
> > Springfield, OR USA
2009-08-03 by Elk Latham
The Emax SCSI interface is for Hard drives only.
To: emax@...m
Sent: Monday, August 3, 2009 10:20:46 AM
Subject: [emax] Re: 6 SCSI kits available
Hi
d
--- In emax@yahoogroups. com, "rpcfender" <rpcfender@. ..> wrote:
> Hi Ted
> Version 2
> revision C
> There is no 5380
> IC 13 is IP255
> IC 49 is IP344
> Thanks
> Royce
> > upgraded.
> > shipping.
> > Kit includes:
> > IP379a PAL
> > 50-pin SCSI internal ribbon cable (non-terminated) .
> > Each kit is $50.
> > shipping.
> > purpose also.
> > did.
> > SCSI Zip
> > SCSI Compact Flash
> > SCSI hard drive
> > IDE CF (works via an ACARD SCSI bridge adapter..... )
> > modifications.
> > may change).
> > This includes:
> > SCSI chipset kit
> > Installation Labor
> > OS Floppy
> > to work properly.
> > installation.
> > Regards,
> > Ted Summers
> > Springfield, OR USA
2009-08-03 by Donnie Smooth
Please remove me from this mailing list please!!!
Date: Monday, August 03, 2009 2:58:46 pm
Subject: Re: [emax] Re: 6 SCSI kits available
Hi
d
> Hi Ted
> Version 2
> revision C
> There is no 5380
> IC 13 is IP255
> IC 49 is IP344
> Thanks
> Royce
> > upgraded.
> > shipping.
> > Kit includes:
> > IP379a PAL
> > Each kit is $50.
> > shipping.
> > purpose also.
> > did.
> > SCSI Zip
> > SCSI Compact Flash
> > SCSI hard drive
> > modifications.
> > may change).
> > This includes:
> > SCSI chipset kit
> > Installation Labor
> > OS Floppy
> > to work properly.
> > installation.
> > Regards,
> > Ted Summers
> > Springfield, OR USA
2009-08-03 by Ted Summers
Emax 1 does not support SDS (SCSI DUMP). So, while you can use G3 with some
Audio / Sample edit software, you cannot use it via SCSI.
If you have the beige G3 tower, you can do transfer via RS422 serial using
the printer / modem port to the Emax.
Done this
However if you got a Blue and White g3 it doesn't have a RS422 serial.
There was an addon board to add the port.....could get that off ebay.
Must use OS 8 or earlier though, if I recall.
The B/W G3 ran OS 9 or 8.5, which was too new for the Audio Sample software
if I recall....
Someone correct me if I am wrong.....
Ted
If it is a blue and white g3, you can install a Stealth Serial Port and use it with the RS 422 port as well.
Sent: Monday, August 3, 2009 12:04:44 PM
Done this
if I recall....
Ted
You can use Passport design Alchemy with OS 8 and OS9 if you can find a copy.
Done this
if I recall....
Ted
Thank you ted.
so the scsi kits you have will enable sue wuth a zip drive?
d
> Done this
> if I recall....
> Regards,
> Ted
2009-08-04 by Colin Peiris
Hello Ted!
Please make myself clear about the model Emax and Emax1. Are those two separate models, if so the model which I have is just bears emax on it. Which I want to upgrade it with your kit. Please feedback.
Colin peiris
> upgraded.
> shipping.
> Kit includes:
> IP379a PAL
> Each kit is $50.
> shipping.
> purpose also.
> did.
> SCSI Zip
> SCSI Compact Flash
> SCSI hard drive
> modifications.
> may change).
> This includes:
> SCSI chipset kit
> Installation Labor
> OS Floppy
> to work properly.
> installation.
> Regards,
> Ted Summers
> Springfield, OR USA
