Emax
SCSI termination question
2010-01-12 by thenewyorkcowboy
I am still having intermittent failures with my SCSI setup and have a general question about termination.  At this point I am convinced that the ZILOG chip just was not advanced enough in it's day to be compatible with devices that SAY they are backwards compatible.  The data sheet says the chip does 3mb where we all know SCSI-1 should have been 5mb.  If a major standard like that was compromised, I can't imagine what other shortcuts they took.
If the EMAX II models that originally were HD models had an internal drive mounted by the factory AND still had the external SCSI port, how exactly did they get around proper termination?  Did they come with a 25 pin terminator that acted like a cap to the port that you had to keep track of as an accessory?
I am considering installing a mini toggle SPST switch that sticks through one of the slots in the back to turn on TRMPWR on the ACARD adapter to terminate the ZIP drive I am trying to install for when I want to connect an external device as well.
Any help or suggestions?
Re: [emax] SCSI termination question
2010-01-12 by Ted Summers
Termination should be at the end of the cable.
It prevents "reflection" of signals through the cable. Even cable length
that is "unconnected" can reflect signal.
Turning on termination when the drive / connection is not at the end of the
cable is not the "best practice" way of terminating it and may result in
intermittent issues.
Depending on how you have SCSI in Emax hooked up, there is the possibility
of two termination setups.
On rev 3 boards / factory modified boards where there are two headers (one
50 pin for internal and one for external DB25 right off the logic board),
then the 5380 could be considered to be basically in the middle of the SCSI
bus chain.
In that scenario.... as a single chain
INTERNAL DRIVE with TERMPWR on 50pin connector ------ 5380 SCSI controller
------- external port from logic---- external drive---- external drive ---
terminator
However, if you only have the 50 pin connector, then I believe it should be
like this if using internal and external drives:
5380 ----- internal drive (no term) ------ external connector ------
external drive ----- terminator
when there is no external drive I would put the terminator right on the
external connector.
Keep in mind that (IIRC):
* each connection on the scsi bus = loss of length of 6 inches of cable from
"max length" the chain is allowed to be.
* cables should always be kept to the minimum length possible to prevent
issue, but connectors should be at even spacing. The spacing is typically
determined by the length of the cable and different mfrs do not always
adhere to the spec to minimize reflection down the cable length.
*you may need an active terminator or passive depending on the bus.
YMMV, but that is what I know from my experience with SCSI (generally
speaking- from "on the job" using SAN storage and JBOD storage, and internal
HD, Tape, and CDROM - all SCSI).
Ted
On Tue, Jan 12, 2010 at 9:23 AM, thenewyorkcowboy <
> accessory?
Re: SCSI termination question
2010-01-14 by thenewyorkcowboy
Ted, E-synthesist and Tristan always have something wonderful to contribute, and I took all of your advice to heart, but I am still oscillating between 'knowing' and 'guessing'....
https://www.media.mit.edu/resenv/classes/MAS963/history/emu.html
Doesn't give exact timings and seems to show a little helter skelter.
The manual though for the ESI-32 is much more clear on page 202:
"The ESI-32 is shipped with termination power On with the termination
resistors left in place. This assumes that the ESI-32 will be placed at one end of the SCSI chain. The ESI-32 has an automatic system which
ONLY supplies terminator power when it is NOT being supplied by
another device. Therefore, you don't need to worry about terminator
power when connecting the ESI-32."
I was lucky enough to acquire my ESI-32 recently (for $31 plus shipping!!!) with both 32mb of RAM already installed as well as OS 3.02 it is amazing how small this technology is in only one generation of E-Mu from the EMAX II but I cannot determine at what stage these two systems are similar.
> bus chain.
> terminator
> external connector.
> Regards,
> Ted
> > accessory?
Re: [emax] Re: SCSI termination question
2010-01-14 by jammie
its the same for the emax the emax is terminated and provides term power
what ted was saying if you have a upgraded scsi board then if you have an internal drive and the external drive the 1 in the emax needs to have its term off becuase the 50 pin cable goes to the drive inside first then to the back of the machine
if you use just the internal drive then you can set its term to on but if you are going to place more than 1 drive on the scsi chain then it needs to be of and the last drive in the chain needs to be term on
which means that you would need a term block on the scsi connection on the back of the machine when not useing an external drive
as for the esi-32 it has a dual channel scsi controller 1 for the internal and 1 for the external which are both terminated it still only connects 7 drives but can use either channel to conect them
  To: emax@yahoogroups.com
  Sent: Thursday, January 14, 2010 7:52 AM
  Subject: [emax] Re: SCSI termination question
  > bus chain.
  > terminator
  > external connector.
  > Regards,
  > Ted
  > > accessory?
  Checked by AVG - www.avg.com
  Version: 8.5.432 / Virus Database: 270.14.138/2618 - Release Date: 01/13/10 07:35:00
the esi-32 is based on the emulator 3 and not the emax and uses the same filter ic as the e3x
  > bus chain.
  > terminator
  > external connector.
  > Regards,
  > Ted
  > > accessory?
My Emax II is the latter type that came factory fitted with the black external SCSI connector and just has the 50 pin header on the board.  So I don't see how the cable gets routed back unless it is through the traces on the board being the 'first stop' (which would seem to create something of a pseudo-dual channel or pigtail being in the middle) but nevertheless this is the answer I was looking for and why I was thinking about adding a SPST toggle switch out the back slots for termination instead of having a terminator sticking out, as it is one more part to bag up and keep track of on a gig, but I am going to consider it as well simply for the LED status on an active terminator.  I was just surprised that there was no explicit documentation in the Emax II manual about this part of SCSI and no mention of an included terminator either on the board or as a cap to the external socket when not using external devices.  Is there a specific Emax HD manual that states otherwise?
>   ----- Original Message -----
>   From: thenewyorkcowboy
>   > bus chain.
>   > terminator
>   > external connector.
>   > Regards,
>   > Ted
>   > > accessory?
2010-01-15 by jammie
that emax2 factory fitted board  has a dual controller so you need to terminate the drive in the machine and terminate the drive on the outside of the machine if using an external drive
dont need a toggle switch
the termination is done by a bank of resisters in this case there will be 2 banks of resisters 1 for the internal 1 for the external
theres also term power which is where the controler sends 5v power to the hardrive bus power
as some drives require it mostly the iomega zip drives dont provide term power and so if your controller does not send it they wont work this was a problem for the ensoniqs
akai provide it but use a surge transister fuse for current feed back so when using drives with akai your supposed to turn of term power or it can blow the fuse which caused the sampler to be permanently stuck on disk not ready status being totally useless i have brought many akais this way and £10 later permanat fix and the are good to go
  Sent: Thursday, January 14, 2010 8:17 PM
  > > bus chain.
  > > terminator
  > > external connector.
  > > Regards,
  > > Ted
  > > > accessory?
  Version: 8.5.432 / Virus Database: 270.14.140/2621 - Release Date: 01/14/10 12:39:00
2010-01-15 by thenewyorkcowboy
That makes a whole hell of alot of sense, Jammie.  I am not well versed in sampler hardware but my 'new to me' ESI-32 came with a 'broken' sticker on the back about voiding the warranty and I really can't imagine opening up the case on the Emax II every time you want to change termination.  Auto sense makes sense.
I am going to treat the EMAX II as a normal computer once I put it back together and not worry about termination at the outer port at all like the external port of a PCI card.  This may have been my problem all along is looking for that termination point and flipping too many switches and jumpers.
With the lack of documentation I was thinking 'caveman' but it is the opposite.  They didn't feel the need to document something that was intuitive.  Only the external devices need termination through the port once they are hooked up.  Otherwise all internal devices are set to only one termination point and that's it.  Very freakin' cool.  I can terminate one point and stitch it back up.
>   > > bus chain.
>   > > terminator
>   > > external connector.
>   > > Regards,
>   > > Ted
>   > > > accessory?
