Emax
EMXP and emax HD OS 1.1
2011-03-17 by Matthieu Roche
Hi all,
I own an Emax HD, and I just installed the card reader, following Ted Summers'instructions. The problem is that the Emax runs the HD OS 1.1 (not SE). Using EMXP, I can't install the OS on the SD card, because EMXP tells me I have to use the Plus OS. Is there another way to install the HD OS on the SD card?
Thanks a lot!
Matthieu
Re: [emax] EMXP and emax HD OS 1.1
2011-03-17 by Jason Mc
When I updated my Emax  to the cf drive, I needed to keep a floppy drive
installed. After I booted the floppy with the HD OS, I then formatted and
transferred the OS to the CF Card.
After this  was complete, I turned off the unit jumpered the floppy pins and
removed the floppy drive. Now my Emax boots from the CF Drive and I can
remove the CF drive and add banks to it via EMXP.
All works great.
On Wed, Mar 16, 2011 at 8:24 PM, Matthieu Roche <roche.matthieu@...>wrote:
> Hi all,
> the SD card?
> Thanks a lot!
> Matthieu
Re: EMXP and emax HD OS 1.1
That is the procedure I suspected. Thanks a lot! :) I will give it a try. I am still interested in other possibilities. :)
> All works great.
> > Hi all,
> > the SD card?
> > Thanks a lot!
> > Matthieu
2011-03-20 by esynthesist
I will check if I can change this in EMXP, and if it is possible to add support for the OS HD and OS SE HD on removable media.
To be honest I didn't even remember that I had built in a restriction to the Plus OS only - after checking the code it seems this was done because I couldn't test/confirm the other possibilities at that time.
If the change is small, it will be part of the next version v2.10 (expected in the coming weeks).
///E-Synthesist
> > All works great.
> > On Wed, Mar 16, 2011 at 8:24 PM, Matthieu Roche <roche.matthieu@>wrote:
> > > Hi all,
> > > the SD card?
> > > Thanks a lot!
> > > Matthieu
2011-03-25 by Matthieu Roche
Oh, thanks a lot :) That would be a great mod, if it is possible to implement it. EMXP is a great piece of software, very helpful when you have an Emax :)
Matthieu
> ///E-Synthesist
> > > All works great.
> > > > Hi all,
> > > > the SD card?
> > > > Thanks a lot!
> > > > Matthieu
