I hear ya on the transients. I agree. It's hard to get a bad sound of the
Emax 1 no matter what you do or how you use it.
-keep Emax'ing
On Sat, Apr 23, 2011 at 1:39 PM, el macaco <elmacaco@...> wrote:
> Granted the emax always sounds good and with great character, but I like
> the sound when overdriving the input slightly and even without od I like the
> sound of transients sampled in versus sampling to computer then emxp to
> emax. I didn't know sample dumps limit the transposition range. Weird.
> To: emax@yahoogroups.com
> From: jamesulibarri@...
> Date: Sat, 23 Apr 2011 12:43:05 -0600
> Subject: Re: [emax] Re: using SDS with Awave
> Naw, I don't buy that. That's an old urban legend. I have A/B'd two
> samples monitoring with a pair of Emu PM5's and a JBL sub and it sounds the
> same. The *sample input* samples sound a little hotter because it's
> perceived loudness verses actual loudness, because it picks up more noise
> in
> the A to D process. Not that I am against noise in some situations due to
> the music I make. But the rumors people say that they don't sound as good
> with midi dumps have been spread for years. And I have tried it with my
> Emulator III and SP1200 and it's the same there too. It's cleaner too.
> There isn't so much of that decimated aliasing at the tail of the sample
> that you get sometimes. But one thing that I haven't figured out is how
> to
> span a sample across keys that can be played across keys that sample input
> method allows. So with that in mind, a person should use both methods
> probably as I think about it.
> On Sat, Apr 23, 2011 at 9:30 AM, el macaco <elmacaco@...> wrote:
> > The sample inputs sound so much better tho...
> > Date: Sat, 23 Apr 2011 09:15:27 +0000
> > Subject: [emax] Re: using SDS with Awave
> > I figured it out if anyone gives a rat's ass. But Awave works 100%
> > with the Emax 1. I sold my Emax SE rack last week and now am using the
> > keyboard version (non-SE).
> > I doubt anyone is doing dumps with Awave, but if anyone is, than make
> sure
> > you use the Audio Processing Wizard and convert the samples to the
> samples
> > to only the same sampling rates that the Emax 1 supports.. for example
> > 42000. Do not use any commas or it will jack the program up, and it
> won't
> > transfer. I wish someone told me this. Also make sure you connect your
> > midi interface to and from the unit to the Emax 1. So it makes a complete
> > handshake. One way communication won't work as it will find the header
> but
> > no end of the loop. Then use the 12-bit drop down and select the Slow
> Dev.
> > option and hit send. As I said only use targets 15-75 as those are the
> keys
> > mapped to the Emax 1. If you do anything lower or higher than it won't
> > work. So ultimately you can have a different sample on every key.
> > This is very cool for me now as my SP1200 and Studio 440 do not have any
> > kind of resonation control for the filter.
> > After figuring this out on the SP and the Emax, I will never use the
> > sampling inputs again. It's a crap ton easier to use a wave editor and
> just
> > do dumps now.
> > --- In emax@yahoogroups.com, James Ulibarri <jamesulibarri@...> wrote:
> > > I am a big fan of using Awave doing SDS dumps to the SP1200 with a
> little
> > > Emu 2x2 midi interface and it works like a champ,
> > > finally after about 2 years of banging my head against the wall. So I
> > have
> > > "tried" to do the same thing with my Emax SE rack with the same
> procedure
> > > and it says a message to the effect of "Transfer Complete" or something
> > like
> > > that. The same message as the 1200, which works now. But the problem
> is
> > > nothing is there! I will go in and make a new Bank but no matter what
> I
> > > cannot find the sample. It's really annoying. I can't say for sure
> > but
> > > it seems like the data gets sent over but it dissapears or I can't
> access
> > > the sample, even after mapping it or trying to map it. And looking at
> > my
> > > memory available at that point, I can see that some ram did get eaten
> up
> > a
> > > little bit, so it must be there. Anyone have any advise or do SDS
> dumps
> > > with the Emax? I am close but something isn't right. I say it's
> gotta
> > be
> > > me, operator error, but where does my samples go? Balls, this sucks.
> > > thanks
> > > [Non-text portions of this message have been removed]
> > Emax and Emax II User's Group Website
> > http://www.silveriafamily.comYahoo! Groups Links
