I haven't had my Emax 2 for long, but when I was sampling my CZ with it,
what ever was coming in the Emax was getting out by it's output. I could be
different with an Emax 1.
On Fri, Dec 30, 2011 at 3:21 PM, Chase Smith <plus_321@...> wrote:
> I think there is no monitoring on an emax, unless I don't know the
> setting. I generally get around this by recording my sample in soundforge
> and then playing it back to the emax so I can trim it to exactly what I
> want.
> From: Nik Kinloch <nikkinloch@...>
> To: emax@yahoogroups.com
> Sent: Friday, December 30, 2011 2:27 PM
> Subject: Re: [emax] Emax audio thru?
> Off the top of my head, I don't think the Emax has 'audio monitor' when
> sampling. You'll need to monitor separately AFAIAA. Did you check the
> manual? Just rewiring the studio ATM so can't check with mine right now
> - up to my eyeballs in bantam patchbays!
> Congrats on getting the audio in working though!
> On 30/12/2011 19:20, jdchevallier wrote:
> > Still trying to get my emax to sample!
> > I'd been having problems with the machine not getting an input signal
> (or a very weak one.) Before shipping it off for repair I pulled each of
> the chips inside, dusted the board and reseated them. Not too technical,
> but I now have a visible signal when sampling...it seems to have worked.
> > When sampling I can however only see the signal in the vu mode...I can't
> heard anything. Should I be able to hear the audio passing from my
> turntable, through the emax, prior to sampling? I can only hear the signal
> after I've sampled, which obviously makes picking an exact spot on the
> record to sample a bit tricky!
> > Not sure if there is a setting I've disabled, if this is yet another
> problem with my board, or something else.
> > Any insight, as always, is appreciated greatly.
> > Joel
> > Emax and Emax II User's Group Website
> > http://www.silveriafamily.comYahoo! Groups Links
