Disable Emax1 HD...?
2012-01-25 by zoog_angelspit
I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies The HD is dead. I can not save or load onto BANK00. Floppies working A-OK Q: How do i tell the EMAX1 to ignore the HD? Can i just physically remove it? thank you!
2012-01-25 by Ted Summers
Yes- you can physically remove it. Most are replacing HD with flash media drive... On Wed, Jan 25, 2012 at 6:57 AM, zoog_angelspit <zoog_angelspit@yahoo.co.uk>wrote: > ** > > > I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies > The HD is dead. I can not save or load onto BANK00. > Floppies working A-OK > > Q: How do i tell the EMAX1 to ignore the HD? Can i just physically remove > it? > > thank you! > > > [Non-text portions of this message have been removed]
2012-01-25 by Nik Kinloch
You need to use the non-HD version of the operating system.
On 25/01/2012 14:57, zoog_angelspit wrote: > I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies > The HD is dead. I can not save or load onto BANK00. > Floppies working A-OK > > Q: How do i tell the EMAX1 to ignore the HD? Can i just physically remove it? > > thank you! > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
2012-01-26 by el macaco
You don't have to switch the OS, just boot from a floppy disk and the Emax will ignore the HD unless you tell it to look for it. I highly recommend getting a compact flash drive in there instead of the HD, the benefit of running the emax from the HD or a CF card as HD is that all the processes are much faster than when it has to read the OS from the floppy before every action. Floppy means slooooow. To: emax@yahoogroups.com
From: nikkinloch@... Date: Wed, 25 Jan 2012 22:27:34 +0000 Subject: Re: [emax] Disable Emax1 HD...? You need to use the non-HD version of the operating system. On 25/01/2012 14:57, zoog_angelspit wrote: > I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies > The HD is dead. I can not save or load onto BANK00. > Floppies working A-OK > > Q: How do i tell the EMAX1 to ignore the HD? Can i just physically remove it? > > thank you! > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > [Non-text portions of this message have been removed]
2012-01-26 by Nik Kinloch
If you use a HD version of the OS, but don't have a HD, you will get an error when trying to save anything, as it looks for the disk then times out. The SCSI CF route is by far the best. Apart from the speed advantage, using a CF card with the EMXP software means you can transfer files to and from the sampler, build presets, back up etc.
On 26/01/2012 14:42, el macaco wrote: > You don't have to switch the OS, just boot from a floppy disk and the Emax will ignore the HD unless you tell it to look for it. > > I highly recommend getting a compact flash drive in there instead of the HD, the benefit of running the emax from the HD or a CF card as HD is that all the processes are much faster than when it has to read the OS from the floppy before every action. > > Floppy means slooooow. >
2012-01-26 by Matt
SCSI CF vs hxc floppy emulator: Price and features breakdown? On Jan 26, 2012 6:42 AM, "el macaco" <elmacaco@...> wrote: > > You don't have to switch the OS, just boot from a floppy disk and the Emax > will ignore the HD unless you tell it to look for it. > > I highly recommend getting a compact flash drive in there instead of the > HD, the benefit of running the emax from the HD or a CF card as HD is that > all the processes are much faster than when it has to read the OS from the > floppy before every action. > > Floppy means slooooow. > > > > > > > To: emax@yahoogroups.com > From: nikkinloch@... > Date: Wed, 25 Jan 2012 22:27:34 +0000 > Subject: Re: [emax] Disable Emax1 HD...? > > > > > > > You need to use the non-HD version of the operating system. > > On 25/01/2012 14:57, zoog_angelspit wrote: > > I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies > > The HD is dead. I can not save or load onto BANK00. > > Floppies working A-OK > > > > Q: How do i tell the EMAX1 to ignore the HD? Can i just physically > remove it? > > > > thank you! > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
2012-01-26 by jack
if yours is hd then a scsi cf drive $50 is way cheaper than a hxc floppy emulator and scsi is fast a few seconds to load a bank $10 for slim floppy and $17 for slim floppy convertor its a 109 euro,s for the new 3.5 version of the hxc floppy emulator but as of yet it has not been released
Sent: Thursday, January 26, 2012 4:22 PM
Subject: RE: [emax] Disable Emax1 HD...?
> remove it?
> > thank you!
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1901 / Virus Database: 2109/4766 - Release Date: 01/25/12
[Non-text portions of this message have been removed]2012-01-26 by jack
the problems people were having was due to a cupupted version of the se hd os but there is not that problem any longer due to the fact that i reloaded the working versions to the files section they come under jammie.emma its an easy process and does not take long todo there are 2 ways of fitting the cf drives there the keyboard way and the rack way as the bracket systems are different on both
> remove it?
> > thank you!
[Non-text portions of this message have been removed]2012-01-26 by Mel24
What model cf drive to use? Sent from my MetroPCS Wireless Phone Ted Summers <djtbs1@gmail.com> wrote:
>Yes- you can physically remove it. >Most are replacing HD with flash media drive... > > > >On Wed, Jan 25, 2012 at 6:57 AM, zoog_angelspit ><zoog_angelspit@yahoo.co.uk>wrote: > >> ** >> >> >> I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies >> The HD is dead. I can not save or load onto BANK00. >> Floppies working A-OK >> >> Q: How do i tell the EMAX1 to ignore the HD? Can i just physically remove >> it? >> >> thank you! >> >> >> > > >[Non-text portions of this message have been removed] > > > >------------------------------------ > >Emax and Emax II User's Group Website > >http://www.silveriafamily.comYahoo! Groups Links > > >
2012-01-26 by Ted Summers
Look on the group in the database section. Information is there. PCD-50b and other. On Thu, Jan 26, 2012 at 12:00 PM, Mel24 <melechdidymus24@yahoo.com> wrote: > ** > > > What model cf drive to use? > Sent from my MetroPCS Wireless Phone > > Ted Summers <djtbs1@...> wrote: > > >Yes- you can physically remove it. > >Most are replacing HD with flash media drive... > > > > > > > >On Wed, Jan 25, 2012 at 6:57 AM, zoog_angelspit > ><zoog_angelspit@...>wrote: > > > >> ** > > >> > >> > >> I'm wanting to disable my Emax1 SE HD's hard drive and only use floppies > >> The HD is dead. I can not save or load onto BANK00. > >> Floppies working A-OK > >> > >> Q: How do i tell the EMAX1 to ignore the HD? Can i just physically > remove > >> it? > >> > >> thank you! > >> > >> > >> > > > > > >[Non-text portions of this message have been removed] > > > > > > > >------------------------------------ > > > >Emax and Emax II User's Group Website > > > >http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > [Non-text portions of this message have been removed]
2012-01-26 by Matt
Can i do this on my esi 2000 also? On Jan 26, 2012 1:55 PM, "Ted Summers" <djtbs1@...> wrote: > Look on the group in the database section. > Information is there. > PCD-50b and other. > > > > On Thu, Jan 26, 2012 at 12:00 PM, Mel24 <melechdidymus24@...> wrote: > > > ** > > > > > > What model cf drive to use? > > Sent from my MetroPCS Wireless Phone > > > > Ted Summers <djtbs1@...> wrote: > > > > >Yes- you can physically remove it. > > >Most are replacing HD with flash media drive... > > > > > > > > > > > >On Wed, Jan 25, 2012 at 6:57 AM, zoog_angelspit > > ><zoog_angelspit@...>wrote: > > > > > >> ** > > > > >> > > >> > > >> I'm wanting to disable my Emax1 SE HD's hard drive and only use > floppies > > >> The HD is dead. I can not save or load onto BANK00. > > >> Floppies working A-OK > > >> > > >> Q: How do i tell the EMAX1 to ignore the HD? Can i just physically > > remove > > >> it? > > >> > > >> thank you! > > >> > > >> > > >> > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > >------------------------------------ > > > > > >Emax and Emax II User's Group Website > > > > > >http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
2012-01-27 by jack
yes and you dont need a slim floppy for the esi
Sent: Thursday, January 26, 2012 10:05 PM
> PCD-50b and other.
> floppies
> > remove
> > >> it?
> > >> thank you!
Version: 2012.0.1901 / Virus Database: 2109/4767 - Release Date: 01/26/12
