Emax
ESI 400 - Save to internal HD
2012-08-29 by tl200024
Hello. I have an ESI 4000, and have successfully loaded into it the Alan Wilder Depeche Mode sounds. It took me a long time to get the sounds into the ESI 4000 through the 100MB external zip drive. My problem is, as soon as I turn the machine off, the data is lost from the internal memory. I tried pressing the Save button, however it will only let me choose a floppy drive, or zip drive to save data, not let me save to the internal hard drive. My question is, can I save my sample and preset data into the ESI 4000's internal HD like I can with the Emax II when I save all 16 bit? Thank you very much for your help with this issue.
Tony
Re: ESI 400 - Save to internal HD
2012-08-29 by JMP
You do realise the ESI4000 doesn't have an internal hard drive as standard unless you've installed one? Just checking. ;)
If you've successfully loaded and saved to HD before, not sure why not working unless you've set the SCSI ID of your zip drive to the same as that allocated to the HD....?
> Tony
