To: emax@yahoogroups.com
Sent: Monday, August 27, 2012 9:01 PM
Subject: [emax] Re: Hard Drive for Emax HD
I'm in Sheffield, and you?
--- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> i can do it for you
> were abouts are you in the uk
> From: deanhoner@...
> Sent: Monday, August 27, 2012 8:33 PM
> OK thanks for that. Sounds a bit complicated to me...
> Is there anyone in the UK that could sort this out for me? I dont mind paying!
> --- In emax@yahoogroups.com, "jammie" <jammie.emma@> wrote:
> > yes if its a hd it has an internal 50 pin scsi copnnector and a 26 pin idc connectorfor adding a 25db scsi cable but you need to punch a hole for the 25db socket
> > if you fit the pcd-50b you will need a slim floppy drive and convertor
> > for every thing to work properly other wise you have to do some jumper wires to disable floppy drive so that it can boot from just a hd
> > From: deanhoner@
> > Sent: Sunday, August 26, 2012 11:55 AM
> > OK So the PCD-50b is installed in place of the floppy drive and I simply disconnect or remove the Hard Drive internally?
> > The PCD50b is SCSI, are there SCSI connectors inside the EMAX HD or will it need modifying?
> > Thanks
> > --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote:
> > > Get a flash drive like a PCD-50b from mechware.
> > > Note only the PC-Card slot works in the drive with the Emax....
> > > Then you can ditch the noise and easily change the media
> > > And use EMXP to build up some images.
> > > If you want it internal you can get a slim floppy drive.
> > > See my site for examples
> > > http://djtbs1.wordpress.com/
> > > On Aug 25, 2012, at 8:15 AM, Dean Honer wrote:
> > > Hi
> > > I'm a new member of the forum.
> > > I have just bought a nice Emax HD keyboard. It came with no floppies. The
> > > hard drive is incredibly noisy and only works intermittently. Are there any
> > > replacement hard drives available for the Emax? When working the software
> > > and sound banks load up just fine.
> > > Thanks
> > > [Non-text portions of this message have been removed]
