Emax
New to the group
New to the group
2012-09-20 by dawtechie
Hi everyone, just joined after getting my first emax. I think it is a plus model 2100, SE on the front, no hd inside, but has what looks like factory scsi. The boards say ver A but there are also stickers that say "B". It is in almost new shape, original box, the backlight works. Unfortunately, if I am lucky I can get the floppy drive to read about 3 times the screen gives it's welcome message and stops. I am thinking about pulling the fd, but would like to bypass it and boot from the external scsi connector. I would appreciate any suggestion.
Thanks, Jeff
Re: [emax] New to the group
2012-09-20 by Ted Summers
You can do it with a SCSI drive that is at ID0.
But in the event you have a problem with the external drive, you could get stuck.
My recommendation is slim floppy  and flash media drive.
See my webpage for an example
http://djtbs1.wordpress.com/
Ted
Thanks, Jeff
Re: New to the group
Great website Ted, I checked it out while waiting for my account. I will go that route soon, but hoping to get it booted up before I do. I will look for a ID0 drive in my dust bins.
> Regards,
> Ted
> Thanks, Jeff
Re: New to the group - HELP
2012-09-22 by dawtechie
Well, it seems I have a few questions I need help with. My new Emax Plus doesn't want to read the floppy drive and before I put in a new drive I would like to make sure the Emax works. I have an old 535MB DEC SCSI drive. I have access to just about any type of PC setup (I am a computer tech). When I power on the Emax+ the backlight lights up, all the lights flash red and then the Analog Processing light stays lit, sometimes the floppy will make a "read" noise 3 times and the screen will then give its welcome message. That is as far as it goes and does nothing from there. I am worried it is not the floppy, it almost looks new. It came with no disks so I have made my own with EMX.
1. Can I format the SCSI drive outside the Emax with an app like EMX in DOS or is there a better way to go?
2. It looks like I can use CN2 for the connector, is this correct?
3. I can use an external power source for the SCSI drive to test the Emax, but where would I get power for a permanent HD mod? Should I just make an adapter to split the existing floppy power?
Thanks! Jeff
> > Regards,
> > Ted
> > Thanks, Jeff
