To: emax@yahoogroups.com
Sent: Sunday, October 14, 2012 4:41 PM
Subject: Re: [emax] Solder skills
use a continuity meter with a ring sound
plus you should get near zero ohms resistance as its a small short cabble
you need to tape doen the cable so it does not move
its also better if you remove the old solder and clean the joint with some solder brade with none clean flux
then place the cable next to the pin tape in place and solder
with a 0.5mm solder as if its to thick you will over solder it
then solder together making sure it flows properly onto the pad and pin and cable
repeat for the other 3 connections
bell out with continuity meter to make sure you have a circuit if it rings loud and clear you have a good joint connection between both point
Sent: Sunday, October 14, 2012 4:33 PM
Subject: [emax] Solder skills
Having trouble soldering wires to a JM215A. Are there any tricks like using flux? The areas involved are so tiny I bought a magnifying glass but still having trouble.
Also when completed should I test the pin outs with a multimeter? What should I be looking for?
Thanks! Jeff
