thanks ted. when i am able to install the new el foils i will write down
the make and specs of the original screen, hopefully like the emax there
are some alternatives that also don't require the inverter?
ie Newhaven NHD-0216EZ-FL-YBW
<http://groups.yahoo.com/group/emax/photos/album/563354055/pic/list>
--- In emax@yahoogroups.com, Ted Summers wrote:
> It doesn't look like the pin / size match.
> Nor do these put out 100V, which is what the original unit does- they
are
> 60V and 80V respectively.
> i can't confirm either of these work for the intended purpose.
> You may be able to rig any number of items to do the job, but it may
have
> to not be sitting directly on the board (as designed) etc.
> I don't know if you want something "flopping around" as you connect
> pins and wire to the correct points.
> But with the voltage mismatch for output my opinion would be that
these are
> a no-go.
> On Tue, Jan 15, 2013 at 7:34 AM, dutchbeats wrote:
> > thanks ted! so there is no way the one from backlight4you will work?
is
> > there a safe way to test it with the e-mu?
> > > NEC is the original MFR.
> > > And the replacement I had gotten before is obsoleted / unavailable
at
> > mouser or digi-key.
> > > So if you found the original, get it.
> > > On Jan 14, 2013, at 4:22 PM, dutchbeats wrote:
> > > was it also made by nec? i can only find the original nec inverter
on a
> > uk website for £30 each : /
> > > what about the one i linked to earlier, the first one? that is
also
> > three pin 5v
> > > > I dunno- I was able in the past to get the EXACT replacement
inverter
> > from
> > > > mouser.com
> > > > On Mon, Jan 14, 2013 at 8:28 AM, dutchbeats wrote:
> > > > > i have a few e-mu eiiix samplers that use the same inverter as
> > emax
> > > > > and notice that backlight4you carries a few types of
inverters. i
> > > > > emailed them asking if i could use this one
http://www.backlight4you.com/product_info.php/info/p777_5-Volt-Inverter\
> > > > -for-EL-Panels-up-to-105cm2-area.html >
> > > > > (5v) and he suggested i use this
> > > > > one
http://www.backlight4you.com/product_info.php/info/p818_6-Volt-Inverter\
> > > > -for-EL-Panels-up-to-40cm2-area.html >
> > > > > (6v) instead because of the small
> > > > > screen size of the eiiix. or, he suggested i use the 'nearly
silent
> > > > > version' here
http://www.backlight4you.com/product_info.php/info/p915_3-Volt-Inverter\
> > > > -for-EL-Panels-up-to-60cm2-area.html >
> > > > > , along with a voltage regulator
http://www.backlight4you.com/product_info.php/info/p950_DC-Voltage-Regu\
> > > > lator-3-Volt--100mA--TO-92.html >
> > > > > . the original inverter in the e-mu is
> > > > > 5v correct?
> > > > > [Non-text portions of this message have been removed]
