The flanging effect on the "2nd try" sounds like you're triggering the sample more than once, so you might be onto something with the omni/poly mode. Are you triggering it from the Emax keyboard *and* via MIDI?
On Jan 15, 2013, at 4:57 AM, papluss wrote:
> I've tried sampling thru mixer instead, with emax output muted so no feedback possible (but emax doesnt seem to output when in Vu mode or while sampling)
> soundcard outputs are -10dB into mixer into emax.
> the crap is still there.
> can someone tell me if emax could generate this kinda digital sound if some kind of converter problem.
> and can you confirm that there is no possible way of monitoring the emax input?
> I found a solution to the flanged sound tho, setting up the midi to poly instead of omni and changing the midi basic channel to something else.
> That is quite obscure and involve a weird behavior of my nord stage as master keyboard, i wont go to long on that, i can explain what i found if someone runs into the same problem, but now my problem is 'just' about that digital noise.
> thanks
> --- In emax@yahoogroups.com, "jammie" wrote:
> > yes that would cause the chorus fx as its a delayed version
> > and will be out of phase this will also cause frequencies to be removed and will give you a dirty muffled noisy sound
> > From: Nik Kinloch
> > To: emax@yahoogroups.com
> > Cc: papluss
> > Sent: Tuesday, January 15, 2013 10:59 AM
> > Subject: Re: [emax] Re: bad sound
> > Are you monitoring back through the soundcard? Sounds like the output is
> > getting fed back into the input.
> > On 15/01/2013 10:48, papluss wrote:
> > > Ok
> > > I have bypassed the headphone amp, made the signal hotter into emax.
> > > Sounds perhaps a bit better. (uploaded try2: https://soundcloud.com/paplusse/sets/emax-sampling-noise-problem)
> > > I know it sounds like a digital noise, but I can't hear it from the RME UFX soundcard. It is very clear when i stop the playback early and keep emax sampling, then when emax stops sampling the noise stops (the recording carries on a little)
> > > Also at the begining i retriggered the sample to make you hear the nearly flanged type sound i get, with slightly different sound on every trigger.
> > > At first i though the chorus was on or that the sample was on 2 voices playing together, but chorus is off, and i don't master yet the emax 2 voice architecture, but on a menu quick tour, i couldn't see anything abnormal.
> > > Could the emax generate that digital noise? Would that be AD/DA conversion problem?
> > > How do you guys monitor your emax input?
> > > Thanks for your time guys.
> > > dave
> > > --- In emax@yahoogroups.com, krikor kouchian wrote:
> > >> yes i didn't see that
> > >> sure don't use the headphone amp to sample in the emax!
> > >> Le mardi 15 janvier 2013, Human Being a �crit :
> > >>> Take the headphone amp out of the equation and post the results. I would
> > >> guess that is what's raising your noise floor.
> > >>> On Jan 15, 2013, at 1:18 AM, monsieur escargot wrote:
> > >>>> I've uploaded the original file now. yes it is off the computer,
> > >> unmastered
> > >>>> drum session bit.
> > >>>> the gain was set to 0dB on the emax and its Vumeter was going over half
> > >>>> way. I had tried it hotter, but worse results, and i made sure i was
> > >>>> sending mono signal and i checked the audio cable.
> > >>>> It doesnt do it with the few samples on disk supplied with the rack.
> > >>>> for the gain stagging, is it correct that you can't audition what you are
> > >>>> sampling through the emax? only the result once you trigger it? I send
> > >>>> signal to emax though an headphone amp which can mono and monitor thru
> > >> the
> > >>>> other channels either on headphones or mixer. Can't see what im doing
> > >> wrong
> > >>>> with gain staging, but in a way i hope it is me and not the machine!
> > >>>> thanks
> > >>>> dave
> > >>>> On Tue, Jan 15, 2013 at 9:12 PM, Human Being abigblackwave@
> > >>> wrote:
> > >>>>> Honestly, it sounds like you were sampling something off of your
> > >> computer
> > >>>>> and didn't utilize proper gain staging.
> > >>>>> On Jan 14, 2013, at 9:34 PM, papluss wrote:
> > >>>>>> hi.
> > >>>>>> first sampling on my 'new' emax1. And it sounds like there is
> > >> something
> > >>>>> wrong with it.
> > >>>>>> Would you be able to direct me towards the problem by hearing those
> > >>>>> samples i made?
> > >>>>>> thanks guys!
> > >>>>>> dave
> > >>>>> [Non-text portions of this message have been removed]
> > >>>>> Emax and Emax II User's Group Website
> > >>>>> http://www.silveriafamily.comYahoo! Groups Links
> > >>>> Monsieur E.
> > >>>> dave at mamakuproject dot com
> > >>>> youtube dot com/mamakuproject
> > >>>> NZ:+64 (0)273214581
> > >>>> France: +33 (0)675322709
> > >> http://www.krikor.fr
> > >> +33632199413
> > >> bookings:
> > >> France/Suisse/Benelux: fanyktdj@
> > >> World: laetitia@
