emxp uses the emx format img files
omniflop software cant read this image file
and cant write it
it onto a floppy disk
now the omniflop driver is a set of instructions
that tells the floppy controller how to write certain formats to a floppy
drive
emxp uses this driver to tell the floppy controller
that its using the emax floppy disk format and so can read and write emax floppy
disks
and write banks to it
as i said emxp and omniflop software are 2
different programs and they dont use each others software
they just use the same floppy system omniflop
drivers the floppy drive controller drivers and the floppy drive
drivers
omniflop only does raw.img formats it cant read any
others an d wont write any others
so emx/out/ghk/dms/and many other floppy formats it
cant read or write
for these there are other image utilities most are
dos based like glieber which does the ensoniq
then theres the sdisk .out formats for
roland
fdisk
total commander
teledisk
and many other image making programs
the hxc floppy emulator uses its own format and has
drivers to read certain other formats
so that its controller can emulate the actual disk
format of the actual machine its emulating so the synth or sampler can read and
write to the images
so the only time you should use omniflop for the
emax is to create the se upgrade disk
and thats it
all other functions should be done with the emxp
emxp works period and i have been using it since
esynthesis first anounced it and sent back info for things not
working
we have alos talked about other formats over the
years like the mirage floppy and sample format
the korg dss1 is another format talked about as
esynthesis made the dss1/dsm1 library available in img format as it was a wierd
dos format before that was hard to get to disk so he converted the lot to img
format so it could be read and imaged by omniflop software img
program
the reason why you were having such problems are
your confusing the 2 software programs
Sent: Sunday, October 27, 2013 7:47
AM
Subject: Re: [emax] Emax I HD Plus
OS
no it cant
as the ez1 file is an iso file which is a
hd/cdrom img fromat
omniflop only does floppy formats upto 400k to
1.44mb
the 400k being ensoniq mirage
most 720k formats
ensoniq 820k formats
and many others
Sent: Sunday, October 27, 2013 2:52
AM
OS
So theoretically then
OmniFlop should be able to
Take an .ez1 image file created in EMXP and write it to
floppy disk?
Anytime I use omniflop it ends up looking for a.IMG file and can tell
me if it's recognized
But is unable to write the Emax OS disk image, even when I
direct OmniFlop to the EMX file. Instead I have to use EMXP
or the Emax itself to write an Image file that can be bootable into
Emax. and so far due to a bad Emax floppy disk drive I can't even do
that's
i've tried several times and to this very day
I've never gotten EMXP, let alone OmniFlop to do so and I've been
working with BOTH programs for almost a almost week now, so
that should definitely make me an expert (ha ha)
Question: can OmniFlop directly copy/clone an
Emax Floppy disk created either on an Emax or EMXP/EMX?
so that you could give it to another person and they could load it on
their Emax?
On Saturday, October 26, 2013, jammie wrote:
you cant use omniflop to write the os
you need to write the os in emxp
emxp uses the omn iflop driver to format and write
to emax floppy
but its done inside emxp
you use omiflop to write images made
and why you write the se upgrade disk in the
omniflop software direct and not emxp
your confusing the 2 programs
emxp = format emax disks write to emax floppy
disks
omniflop = reading and writing to and from img
format raw floppy image files
be it emax/ensoniq/korgdss1/korg t 1/2/3/ex and any
other format it can create raw images from
tyhey are 2 seperate programs
emxp just uses the omniflop driver to createw its
disks but does not use the omniflop software to write images
thats where you are getting confused
12:03 AM
OS
Jammie
Omni flop is a little confusing I will admit.
The problem is Omni looks for an image or .IMG file when it
goes to write the OS and as we know Emax OS images are .EMX
extensions.
I think this is where he is getting confused.
Ted has said before and I would have a tendency to agree that the
best software disks for an upgrade are the ones written by other Emax
Machines already containing the upgrade operating system rather
than trying to write one off of omniflop or EMX P or EMX
for that matter because if the heads off of alignment in the PC floppy
disk drive then The Emax won't be able to use that floppy. That's
the very same problem I'm going through right now with mine. I am trying
to upgrade to the plus OS SE HD Rev 1.1
I can't do it
because my PC disk drives will not write disks that my Emax can
read
So even if on the flop or EMX P or EMX writing good disks my
Emacs this drive which is a little kludgy over the years can't read
them.
Terrified this I poop bag send me some discs of the plus operating
system that he wrote on his machine and I'm going to test them to see if
they will load and upgrade mine. If they will I know that my machine has
a bad floppy disk drive because it will read this it's written on the
end it will read this written by another Emacs machine. It will only
read disks it creates for itself. This is why I have a tendency to
believe my machine has a bad FDD. it can only read what it can write.
Your BMX P and on the flop cannot read disks that my
Emax creates.
My suggestion is that he take his FDD and create a software
floppy off his own Emax.
If any MXP or on the flop read that disk chances are he to like me
haas a bad FDD
In his Emax
Just some troubleshooting tips
I had to learn the hard way
For the longest time I thought my problems were all due to eat and
XP and an incompatibility with my Windows PC
Fact is it was not a problem with EMXP and my PC it was a
problem might Emax floppy disk drive creating disks that EMX P and
OmniFlop could not read
Has he tried to create a disk on his own Emax then take that
disk and see if EMX P or OmniFlop can read it? fif they won't
read it chances are he has a misaligned floppy disk drive in his
Emax too
On Saturday, October 26, 2013, jammieI haven't
got the words to tell you anything
You want to hear
so I just won't try to
say anything
Anymore wrote:
like i said you need
the omniflop img of the se upgrade disk
its under esynthesis
name
emxp cant use or create this disk you need to use either
dos like ted does
or use omniflop
its the only
way
the reason you are getting wrong software is because you
have not upgraded
to se
those later os use the code blocks
written into the eprom to work anbd why
you get wrong software
message
<userlists@...>
To:
<emax@yahoogroups.com>
Sent: Saturday, October 26,
2013 9:20 PM
Subject: [emax] Re: Emax I HD Plus OS
Is it necessary to use Omniflop?
> I have EMXP installed
and it works - no error messages. But if the files
> are OK,
then I might be to stupid :-(
>; I put to
Floppy:
> - Emax OS SE 1.1
> - Emax OS SE HD
1.1
> - Emax OS Plus OS 1.0
> I booted up with
every of them but only get the message "Wrong Software"
> or
"Wrong Software Rev."
> I also booted with the regular
OS HD 1.1, copied the newer OS to this
> disc and loaded the
bank again - also "Wrong Software".
Le
Sociere Des Oscillateurs Mystere
No virus found in this
message.
Checked by AVG - www.avg.com
Version: 2014.0.4158 / Virus
Database: 3615/6781 - Release Date: 10/25/13
message.
