Emax
HOW TO MAKE A ZIP.DISK CD/CF Step By Step
2013-10-25 by windrumscoggin@...
CD/CF card the easy way
IN EMXP
first off, this was done using Windows Vista Home basic with an internal IDE ZIP drive.
First thing I do is create a FOLDER called EMXP at THE ROOT of my hard drive.
C:\ emxp
(You can place it on your desktop if you want, I like the root C folder
just for old times EMX stylee sake)
Once you execute EMXP for the first time
it creates 'SUB' folders below
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
To save yourself future confusion, find any Emax Sound banks that you want to put on your zip disk (sound banks look like eb1 or eb2 [emax 1 or emax 2] and can be had from the Box site we all know and love.
Collect up all the Sound Banks you wish to copy to ZIP/Flash/CD then
place them into the 'images' folder...this allows EMXP to 'see' them
so they can be added to the HD/CD disk image you will create and that will be copied on to Zip disk later. Once the zip disk has the sound bank files al loaded onto them, you can delete or move them to another folder for safe keeping so that they don't confuse and interfere with any subsequent images you want to create.
Now onto making the disks!
next, create a disc image.
EMXP MAIN MENU
[5] MANAGE EMAX HD/CD IMAGES-enter
[2] CREATE A BLANK EMAX HD CD IMAGE
it will read "ready to create' a new Emax HD image of size 20 MB Suggested
Image Name is [New Image]
type your name you want for it, then hit enter.
It now creates that new image and places it into the
'images' folder (step 1b. above) with the extension .ez1
Now, back to those files you want on that ZIP disk.
You have already dragged and dropped the eb1 or sound
files you want to eventually go on your zip drive into the 'Images'
folder where your 'ez1' image sits, so the next thing is to RESTORE that image to the Zip disk.
the way you do this is as follows:
EMXP Main Menu
[5] Manage Emax HD/CD images
enter
[1] Manage Existing HD/CD images (*note-remember you made an image already above when you created a blank
image)
Now screen pops up showing you all the images you may have created and the New Image image you created
above should be there. type the number coorespding to it and hit
enter
[3] Restore emax hd/cd image to removable HD
enter the drive number that corresponds to your Zip disk on your PC
next,
This is were EMXP takes the image you created above and puts it on your Zip disk
It will run its routine and whirred away.
It will then say:
"the restore process from image New Image.ez1 has been completed, Press any Key to Continue."
You can then type
[5] "show details of emax removable HD"
It will show everything on the zip that was writen
..Cool, No banks yet but cool...
Now is where that above drag and drop of your bank files comes in handy.
The next step to get them on your zip...so next Esc back back to EMXP main menu and
[1] Manage Emu Emax Emax II images and Disks
enter
[1] Manage Emax Bank Images
enter
Now, you should see all those Sound Bank .eb1 and or eb2 files you dragged into the 'images folder
in the earlier steps. If not, something is wrong, and check if they are in the 'images' folder
If they are you are on the right track!
If you see them all listed, then just click
'A' for All and they will all be selected.
enter
[2] Copy Bank to Emax removable Hard Disk or CD image
enter
Please Enter Emax Removable HD/CD drive letter. Current Drive is 'D' (or whatever YOUR ZIP disk
is assigned to
Enter
You will now see up POSSIBLE TARGET BANKS FOR BANK '(whatever the name of the bank(s) you dropped
into the 'images' folder about-up to about 30 empty banks each with a number and [ ] nest to them.
Enter the numbers and hit 'enter' and do this for every bank you wish to add to the zip disk.
As EMXP adds them to the zip disk it will whir and show some !!!!!
then when done, EMXP will say
'Bank Data of bank 'whatever the name of you bank was' has been copied from 'whatever the name of you bank was.eb1'
to Disk (whatever drive designation letter you have for your Zip disk)
press any key to continue
and you repeat the process for up to 30 banks that you want to put on that zip disk.
Hope my little step by step tutorial helps the dense or more technically challenged among us. It is a very literal program, taking me way back to 1982 for sure, but once you get the hang of it, its easier than loading 'Load *,8 on Commodore 64
Re: [emax] HOW TO MAKE A ZIP.DISK CD/CF Step By Step
2013-10-25 by jammie
thats all in the manual
  To: emax@yahoogroups.com
  Sent: Friday, October 25, 2013 4:06 AM
  Subject: [emax] HOW TO MAKE A ZIP.DISK CD/CF Step By Step
   IN EMXP
   C:\ emxp
  a. Akai1000
  b. images
  c. logs
  d. OS
  e. Temp
  e. Wav
  EMXP MAIN MENU
  EMXP Main Menu
  enter
  image)
  enter
  next,
  It will then say:
  You can then type
  enter
   enter
  enter
  enter
  is assigned to
  Enter
  No virus found in this message.
  Checked by AVG - www.avg.com
  Version: 2014.0.4158 / Virus Database: 3615/6778 - Release Date: 10/24/13
and you really went the long way around
create ez1 image then put your os on it then add your banks then write image to hd
thats the quickest way with out have to go the long way you have explained to people
the ez1 image can only have 35 banks so when creating the image only have 35 banks in it also do a txt of the ez1 image contents this allows you to know what banks and presets are in that bank
once you have done this then put on to hd zip or cf card
then rename folder to to image 1 disk 1
and create a new images folder
  Sent: Friday, October 25, 2013 12:35 PM
  Subject: Re: [emax] HOW TO MAKE A ZIP.DISK CD/CF Step By Step
     IN EMXP
     C:\ emxp
    a. Akai1000
    b. images
    c. logs
    d. OS
    e. Temp
    e. Wav
    EMXP MAIN MENU
    EMXP Main Menu
    enter
    image)
    enter
    next,
    It will then say:
    You can then type
    enter
     enter
    enter
    enter
    is assigned to
    Enter
2013-10-25 by Windrum Scoggin
You still selling any CF cards with your 'special banks' that aren't in the Dropbox Jammie?
IN EMXP
C:\ emxp
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
EMXP MAIN MENU
EMXP Main Menu
enter
image)
enter
next,
It will then say:
You can then type
..Cool, No banks y
Le Sociere Des Oscillateurs Mystere
what do you want on them let me know and i can create you some keymaps for you which you create your own presets
i have lots of stuff from single cycle spectra of all synths in multisample format
you can get 30-40 of these files on a emax bank and by layering them you can create almost any type sound
i also do special noise spectrums for choirs same again multisampled and by layering them you can create very nice choirs and pads
these are all new material so that they are fresh
if you go here you can hear examples i did for the korg t seies super m1 which also only has the same amount of ram as the emax
on these i can get 27 multisamples in 512k
here is a video of some one using my pcm in the t series
Sent: Friday, October 25, 2013 6:44 PM
IN EMXP
C:\ emxp
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
EMXP MAIN MENU
EMXP Main Menu
enter
image)
enter
next,
It will then say:
You can then type
..Cool, No banks y
Le Sociere Des ;Oscillateurs Mystere
Yeah,
That'd be GREAT just let me know how much you want for the CF cards. I am hoping they will already be in EMAX format, right? Load right in?
will listen to your examples when at home tonight.
I woule LOVE to get these kinds of sounds.
I LOVE EMAX generated pads and drum sounds
(the drum sounds just have an awesome grit to them
that modern samplers cannot emulate AT ALL)
If you could sell me preformatted banks that you could put on CF cards that will load right into the Emax via the SCSI card reader I am installing on my emax you would be saving me massive amounts of time trying to get these the box site sounds transferred onto SCSI ZIP disks and loading int that way...If I use any of your sounds in any of my productions I will definately give you sound design credits on the MP3 informational portion of the track or sleeve credits if the tracks are cut to wax (as some of my stuff is.
I really appreciate your offering to allow me to use these kinds of sounds AND putting them on usable CF cards that can be loaded into the Emax.
Not many sound designers want to share their sounds so I really appreciate what you are willing to do her and will pay you for the sounds as well as give you album credits.
Thanks Jammie
IN EMXP
C:\ emxp
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
EMXP MAIN MENU
EMXP Main Menu
enter
image)
enter
next,
It will then say:
You can then type
..Cool, No banks y
i actually rpvide many pcm to different people i provided a massive set for the solaris synth by john bowen
and send new content to john periodically
i also do transwaves for the ensoniq
and do dsp modules for the scope modular
Sent: Friday, October 25, 2013 8:47 PM
Yeah,
Thanks Jammie
IN EMXP
C:\ emxp
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
EMXP MAIN MENU
EMXP Main Menu
enter
image)
enter
next,
It will then say:
You can then type
..Cool, No banks y
Contacting you offline Jammie
Thanks!
Yeah,
Thanks Jammie
IN EMXP
C:\ emxp
a. Akai1000
b. images
c. logs
d. OS
e. Temp
e. Wav
EMXP MAIN MENU
EMXP Main Menu
enter
image)
enter
next,
It will then say:
You can then type
..Cool, No banks y
