EXSP24 sample instrument location
2003-11-08 by dib432
Where are the sample instrument files located in OSX?  My manual is for the
OS9 VST version of the EXSP24, and it says to put them in the VST
instruments folder, which I don't have.
The factory presets are in a folder called EXSP24FactorySoundset inside my
Shared folder.  I also have an EXSP24 Samples folder inside the Shared
folder, but nothing shows up on the selection list.  There's a  Sample
Instruments folder inside my Logic 6 Series folder, but that has the same
problem.  None of this makes sense to me, why is it in the shared folder in the
first place, and why is there an "EXSP24 Samples" folder if the sample player
doesn't even look in there?  For instance: if I put the Factory Soundset folder
inside the EXSP Samples folder, all the selections dissapear from the list.
rrrrrrrrrrrgggg.
Re: [EXS] EXSP24 sample instrument location
2003-11-08 by Hendrik Jan Veenstra
>folder in the
>Soundset folder
>rrrrrrrrrrrgggg.
AFAIK OSX and OS9 are the same in this regard: sampler instruments
(.exs files) should go in the Sampler Instruments folder which is in
your Logic application folder.  The samples themselves can be put
anywhere on your system and will be found when you load an instrument
for the 1st time.
Hendrik Jan Veenstra   h @ k n o w a r e . n l
Omega Art: http://www.omega-art.com/
2003-11-08 by Gregory Anderson
I'm not sure what you are talking about when you say nothing shows up in the
"selection list."  Hendrik is right in that the SAMPLES can go anywhere, and
the EXSP will find them.  I however, have all my INSTRUMENTS in the in the
SHARED folder.  Not the SHARED folder in my home folder, but the general
SHARED folder just inside the USERS folder.
If I move any instruments outside this folder, they are not accessible to
Logic, so that seems to be the only place you can safely put the .exs
(instrument) files.  The .aif (sample) files can go anywhere.
So if you are saying that your .exs files are in the right SHARED folder and
don't show up when you try to load a new instrument into the EXSP GUI, then
I don't know what to tell you.  Except that you have to quit Logic and
reload it if you want it to find instruments you have just moved into that
location.
Gregory
Reply-To: exs-users@yahoogroups.com
Date: Sat, 08 Nov 2003 02:32:05 -0000
Subject: [EXS] EXSP24 sample instrument location
player
folder
