Re: Vienna cube-urgent
2003-11-11 by Huud@aol.com
Urgent,
Has ANYONE on this list purchased the higher end ($2,500-$5,400) Vienna cube
set and have had any negative or positive reults using it with Logics EXs24?
-ANY thoughts would be major appreciated as I am contemplting a new string
library this year.
-Terry Michael Huud
www.Music4TheMovies.com
Re: [EXS] Re: Vienna cube-urgent
2003-11-13 by Cyril Blanc
On 12/11/03 12:20 AM, "Huud@..." <Huud@...> wrote:
> Urgent,
> library this year.
Hello
I am also hesitating between VSL and QLSO.
Apparently you must be very carefull about the hardware you are going to use
as VSL is VERY VERY greedy
If you hacve an high end mac 2x1.2 and with 2 or 3 Gigasampler PC there are
no problems but !
I have just bought a 2x2ghz G5 WITH 2.5 GB for this purpose
By the end of this month we should have figures of QLSO as the EXS version
will be available.
Thanks in advance.
Best regards
Cyril Blanc
France
Please sign the petition ³Apple to support APPLE LaserWriter 300 in MAC OS
X²
http://www.PetitionOnline.com/Ap1c1/petition.html
If you want to be sure I read your answer leave my name in it !
Spam mails are directly going to trash
Re: Re: Vienna cube-urgent
2003-11-13 by Nick Batzdorf
>Urgent,
Yikes!
It's great, and it works great in EXS format. This is what I think of it:
http://mixonline.com/ar/audio_vienna_symphonic_library_5/index.htm
Nick Batzdorf
818/905-9101, cell 590-9101, fax 905-5434
Just to be clear, my ringing endorsement of VSL is not a comment that
you should buy it over QLSO. They're both great in different ways.
Not really, Cyril. You do need two or possibly three machines (unless
the G5 changes that), but it's recorded without reverb, so it's not
really voice-intensive. The Performance samples take up some memory,
but the regular Cube instruments are very efficient. I wrote one
over-the-top huge cue with the kitchen sink in it that fits on one
machine easily.
>no problems but !
Ah, then it's just a matter of what one calls greedy.
>will be available.
Lots of people are going to be interested in how G5s work with QLSO.
QLSO is far more voice-intensive than VSL, of course, since its whole
selling point is that it's recorded with reverb. And it's released in
24 bits, which automatically means 1/3 more data to stream. Kompakt
also seems to be more processor-intensive than EXS even when you're
not using its DSP, but I'm not sure whether that's really true.
Nick Batzdorf
2003-11-15 by technodork_2000
For me the biggest issue has been RAM, the individual basic instruments are
fairly efficient, but if you try and load one of the larger, All Strings Ensemble
sus patches, it can easily chew up all of your ram, just one instance of EXS24
and one patch loaded, nothing else int he session period! I struggled to load 2
instances of EXS24 with 1 sus and 1 stac patch, it easily used up all 1.5gb of
ram on a Dual 1ghz G4.  Of course Logic seems to take more and more ram
just for the autoload these days, typically in the 400 - 500mb range.
I would be interested to hear what others are experiencing?
2003-11-15 by Nick Batzdorf
>Strings Ensemble
>struggled to load 2
You don't have disk streaming turned on, so it's trying to load the
entire program into memory.
Don't feel bad!
Nick Batzdorf
