Re: auditioning
Re: auditioning
2004-01-12 by Jamie Lawrence
> Drum Sample Loading and Programming
> Greetings all,
>    I just wanted to know how everyone here programs their custom
> drum samples on the EXS24.  I'm not sure if its like this for
> everyone, but for me, browsing through drum samples on the EXS24 is
> painfully slow.  It seems to take about 1-2 seconds to load and
> preview the drum samples.  Is their another way to load drum samples
> into zones?
Play a pattern on your kit.
Open the exs24 and then hit edit.
Click on the bass drum for example.
Click on the sample - a window will open showing your drive. If all your
bass drums are in a folder and you click the box that says auto-exchange,
logic will substitute the new sound for the old sound, here you can zap
through available sounds with the pattern playing .
That should help you I think,
Jamie lawrence
Re: auditioning
2004-01-18 by Synthology
Sounds good, I think I'll try that.  The drums being in one folder
is no problem, as most of my drums are separated into categories
such as Snares, hats and so on.  Thanks for the info, hopefully it
will be what I need for now.
Synthology
