Apogee Rosetta 800
Apogee Rosetta 800
2004-06-28 by Andreas Grill
> Hi everybody
> Does anyone use a Apogee Rosetta 800 with a firewirecard? Does it work well
> with ESX24/Logic? Driver quality/support? Is this an option as a Pro Audio
> interface with a G5; a cheaper way to get a good interface when you can¹t
> afford ProTools hardware?
    Thanks Andreas
Re: [EXS] Apogee Rosetta 800
2004-06-29 by Gareth Jones
At 5:45 pm +0200 28/6/04, Andreas Grill wrote:
>  > Hi everybody
>>  interface with a G5; a cheaper way to get a good interface when you can't
Latency is going to big a major issue when you move away from PT.
RME interfaces have digital i/o, good sounding Analog i/o and LOW
latency.  I use mine with Apogee Mini-Me
Best Regards,
Gareth Jones
http://www.garethjones.com
2004-06-29 by Andreas Grill
>>> >  > Hi everybody
>>> well
>>> Audio
>>> can't
    Why is latency going to be a bigger issue than on other interfaces, ex.
MOTU or Metric Halo?
Andreas
Re: Re: Apogee Rosetta 800
2004-06-30 by Nick Batzdorf
Some confusion here.
Gareth Jones <g@...>
Andreas Gill:
I don't think it is, but if so it will have to do with the driver and
also how low a buffer the hardware is happy working with. MOTU can
work with a 64K buffer, I believe, and PT's minimum is 128K (which I
haven't tried yet - the 128K Stream Manager in OS 9 didn't work).
Plus ESB has a little more latency than some other sound card drivers.
Now, that latency is for audio coming out of the computer, i.e. how
long it takes between hitting your MIDI keyboard and hearing the
sound.
The latency Gareth is talking about is when you're recording live
instruments, which have to go through the computer; Pro Tools *TDM's*
(not the Pro Tools LE systems') live recording latency is pretty much
down to the converters themselves, so it's only a couple of
milliseconds, like on a digital mixer.
***HOWEVER*** all three cards mentioned above - RME, MOTU, MH - have
onboard digital mixing, so you can monitor the live input through the
card and get the same 2.5ms latency. As a matter of fact, I believe
those are the only three cards with that feature.
I don't know much about the Rosetta 800, but if as I suspect it does
have standard native audio latency, you could use one of the above
cards instead of its Firewire option - in other words, you'd just use
the Rosetta as a converter and connect its digital I/O to the sound
card.
Nick Batzdorf
818/905-9101, cell 590-9101, fax 905-5434
Re: [EXS] Re: Re: Apogee Rosetta 800
2004-06-30 by Andreas Grill
> Andreas Gill:
> sound.
> card.
    Ok, I think I get it! Thanks guys!
    Andreas
